Vector Calc Homework: Find Unit Vector in Direction of ⃗rP & P to Q
The discussion focuses on calculating unit vectors for points P and Q in a two-dimensional space. The unit vector in the direction of point P, represented as ⃗rP = (−3.0 mm)ˆı + (4.0 mm)jˆ, is derived using the formula rˆP = (x/sqrt(x²+y²))i + (y/sqrt(x²+y²))j, resulting in (3/5)i + (4/5)j. For the second part, the unit vector from P to Q, where ⃗rQ = (8.0 mm)jˆ, requires subtracting the position vectors and applying the same unit vector formula, leading to the expression for rˆPQ.
  • Understanding of vector notation and operations
  • Familiarity with the concept of unit vectors
  • Knowledge of the magnitude formula for vectors
  • Basic algebra for manipulating equations
  • Study the derivation of unit vectors in three-dimensional space
  • Learn about vector subtraction and its geometric interpretation
  • Explore the application of unit vectors in physics problems
  • Investigate the use of vector components in different coordinate systems
Students studying physics or mathematics, particularly those focusing on vector analysis and geometry. This discussion is beneficial for anyone needing to understand unit vectors and their applications in problem-solving.
~Sam~
1. Consider the point P at position ⃗rP = (−3.0 mm)ˆı + (4.0 mm)jˆ. Give an expression for rˆP , the unit vector in the direction of ⃗r.
2. Consider the point P from exercise 1 and another point Q at position ⃗rQ = (8.0 mm)jˆ. Give an expression for rˆPQ, the unit vector in the direction from P to Q.
Not much really..maybe length formula
I was wondering...x/sqrt(x^2+y^2) i +y/sqrt(x^2+y^2) plug it into get (3/5)i+(4/5)j
For part two..would I subtract rQ-rP...so 4.0j-[-3.0i+4.0j)? Or would it be 4.0j-[(3/5)i+(4/5)j)? Then do the same..x/sqrt(x^2+y^2) i +y/sqrt(x^2+y^2)?
There are a lot of characters in what you wrote that aren't rendering correctly, so I'm not 100% sure of what you wrote.
One relevant equation that you didn't think to add is the one for the magnitude of a vector. If v = ai + bj + ck = <a, b, c> is a nonzero vector, then a unit vector with the same direction as v is (1/|v|)v = (1/sqrt(a2 + b2 + c2))<a, b, c>.
  • · Replies 63 ·
