Calculating Force at an angle with kinetic friction coefficient
The problem involves calculating the force applied to a crate at an angle while considering the effects of kinetic friction. The crate has a mass of 12.1 kg and is subjected to a constant acceleration of 1.85 m/s². The coefficient of kinetic friction is given as 0.35.
  • Mixed
  • Participants discuss the setup of the problem, clarifying the direction of the force and the motion of the crate. There are attempts to calculate the normal force and the frictional force, with some questioning the assumptions made about these calculations.
Several participants are exploring different interpretations of the equations involved, particularly regarding the normal force and its relationship to the applied force. Some guidance has been provided on setting up the equations correctly, but there is no explicit consensus on the final value of the force.
Participants express confusion over the calculations and the relationships between the forces involved, indicating that there may be misunderstandings about the application of Newton's laws in this context.
skibum143
A force, F, applied to a 12.1 kg crate at an angle (theta) of 41.0 degrees makes the crate move horizontally with a constant acceleration of 1.85 m/s^2. The coefficient of kinetic friction between the crate and the surface is uk=0.35. Calculate the magnitude of F.
F = ma
Fx = F + friction + N + W = ma
Fy = F + friction + N + W = 0
uk*N = friction
so, F = mg(cos theta) - friction = ma
I first found the force of kinetic friction, by multiplying the coefficient of kinetic friction (0.35) by the normal force (12.1 * 9.8), which equaled 41.5 N.
Then, I found m*a = (12.1 * 1.85) = 22.385.
I then set up the equation: F cos(theta) - friction = ma, or F(.7547) - 41.5 = 22.385
This gave me F = 84.65 N, which is wrong.
Can someone help me see where I'm going wrong?
Thanks!
im not sure if i understand the question u have .. is the crate in a horizontal surface and the crate itself lifted to be at an angle 41 .. or the crate is moving in a plane which is at angle of 41 ?? and mention the direction as well is it upward or downward??
Sorry, the crate is moving horizontally to the right, being pulled by a force F at an angle 41 degrees above the horizontal axis. (most likely a rope or something!)
The crate is not moving up an angle. it is moving across a flat surface, but being pulled by a rope at a 41 degree angle. Is there any way to paste diagrams in here? I could try to scan it...
I think that the setup of your problem is something like the following:
http://img52.imageshack.us/img52/8946/ed96dcopycopy.jpg
so, in that case u have calculated the friction force incorrectly ..
it is true that the friction = (uk) * normal force .. in your case in order to find the normal force you should use Newton`s 2nd law which is :
Fy(net force) = 0 , in your problem this is , normal force + Fy - weight = 0 .. normal force is not always mg as you suggested .. go on from this point and you should get the right answer ..
But if Fy = 0, and normal force + Fy (0) - weight (mg) = 0,
then normal force = weight, so normal force = mg.
Am I missing something??
Oh, but you are saying that:
normal + Fy (Fsin(41)) - weight (mg) = 0
So normal + Fsin(41) = weight
Can I use mg for the F of Fsin(41)?
That would give me a normal force of 40.785
and when I plug it into Fcos(41) - friction (40.785*0.35) = ma
I get F to be 48.568
Is this correct? Because I used mg for the F in the Fsin(41) but then I solved for the F in the Fcos(41)...I'm not sure that is right?
noooooo you can't substitute mg for F .. Your questions is asking for the value of F ..
I suggest you solve the following equations :
Fx = Fcos41 - friction = ma
Fy = Fsin41+normal force-mg = 0
When you substitute you have friction = (ku) * normal ..
I think this is clear enough .. Try again and tell me what you did
sorry, I'm horrible at physics. here is what I think you are trying to explain:
if I solve for normal force using Fy, I get:
normal force = mg - Fsin41
if I plug that into the Fx equation, I get:
Fx = Fcos41 - (ku)*(mg - Fsin41) = ma
If I solve for F, I get F = 122 N
Am I going the right way now?
Thanks for your help.
what you are doing is right .. But i have solved your problem and the answer is not 122 ? .. I solved it twice so i don't give you a wrong answer .. You probably made simple mistake in your calculations .. Try again you should get some value between 60 and 68 ..
I am so confused.
When I do the equation, I get:
.7547F - .35(118.58 - .6561F) = 22.385
.7547F - .2296F = 22.385 + 41.503
F = 121.67
Am I doing some trig function wrong here?
ooooh u had made a simple mistake .. U have a sign mistake .. Ur equation should be :
0.7547F + 0.2296F = 22.385 + 41.503
9K
