Understanding the Wavelength of Photons
  • Context: Undergrad
  • Thread starter Thread starter novjo
    Photon Wavelength
The discussion revolves around the concept of photon wavelength, exploring its definition, the factors that determine it, and the relationship between photon energy and wavelength. Participants also delve into the visualization of electron behavior in relation to photon frequency and wavelength, with references to energy transitions in electronic states and the effects of dispersion in different materials.
  • One participant asks for clarification on what photon wavelength is and whether it is determined by the distance an electron falls from the conduction band to the valence band.
  • Another participant explains that the energy of a photon, as described by the equation E = hc/lambda, determines its wavelength, and that photons are generated when systems transition from high to low energy states.
  • There is a caution against visualizing electrons as "falling" over a spatial distance, suggesting that this terminology can be misleading.
  • Discussion includes the idea that while photons and electrons both have wavelengths and frequencies, they are not necessarily comparable in the way initially suggested.
  • One participant states that wavelength is not an intrinsic property of light and that it depends on the dispersion of the material it occupies, while another adds that "free space wavelength" can be considered an intrinsic property, linking it to frequency.
  • Dispersion is described as a measure of how photon speed and wavelength in a medium change with frequency.
Participants express differing views on the intrinsic nature of wavelength and frequency of light, with some emphasizing the role of dispersion and others discussing the concept of free space wavelength. The discussion remains unresolved regarding the best way to conceptualize these properties.
There are limitations in the discussion regarding the assumptions made about the relationship between energy transitions and photon wavelength, as well as the definitions of intrinsic properties in different contexts.
novjo
What is photon wavelength?!
What is photon wavelength exactly?
I know that the energy of a photon is E = hc/lambda, where frequency = c/lambda and lambda is the wavelength. So, what determines the wavelength of a photon? Is it the distance an electron falls from the conduction band back down to the valence band??
Also, is it incorrect to visualize an electron's frequency as vibration or rotation?? It is difficult to visualize what the frequency of a photon is if it correlates to speed and distance...
Thank you.
I think google and wikipedia are your friends on this one ... that should get you a bit further .. you already have the basic equation there.
I have given brief answers to your questions below.
The energy determines the wavelength, as indicated by the equation. Photons are generated when physical systems relax from high energy to low energy states, and the change in energy of the system corresponds to the energy in the equation above. So, in your example, it is the energy separation reflected by the band gap that determines the photon wavelength.
Note that it is incorrect and potentially misleading to think of the electron as "falling" over some spatial distance. People sometimes talk about systems going from high to low energy as falling .. that is what is referred to in your case.
Thank you.
You seem to be confusing photons and electrons here .. both of them have wavelengths and frequencies, but not necessarily in the way you are asking.
Classically, electromagnetic radiation (photons), can be represented as a transverse wave, like a vibrating string. That is why we talk about frequency and wavelength.
Classically, an accelerating electron emits electromagnetic radiation corresponding to the frequency of its oscillation ... so yes, a vibrating electron, or one traveling in an orbit can emit photons, and the frequency of those photons will be the inverse of the period of the motion.
Wavelength is not an intrinsic property of light. Light has a characteristic frequency. Its wavelength depends on a property, called dispersion, of the material it occupies.
All true, but some expansion on this is possible.
People often use the parameter "free space wavelength" which is an acceptable intrinsic property of light. It essentially is an indication of frequency because no matter what medium you are in, you reference back to what the wavelength would be if you were in vacuum space.
In some fields, people prefer to think about free space wavelength rather than frequency, so it's important to know about this standard.
Dispersion is a measure of how the photon speed (or true wavelength) in a medium changes with frequency.
Thank you. Your elaboration is welcome.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 38 ·
  • · Replies 81 ·
  • · Replies 23 ·
  • · Replies 58 ·
