How Are B-Bbar Pairs Produced at the LHCb?
  • Context: Graduate
  • Thread starter Thread starter tgessler
    Lhcb
B-bbar pairs are produced at the LHCb through the collision of two symmetric proton beams, functioning as a b factory. The production mechanism primarily involves gluon radiation from both protons, leading to a significant forward-backward peaking in the angular distribution of the b-bbar pairs. This phenomenon is kinematic rather than dynamic, with the majority of pairs produced at small or large polar angles close to the beam. Understanding this process requires familiarity with theoretical hadron physics and the use of physics generators like Pythia.
  • Theoretical hadron physics
  • Understanding of Feynman diagrams
  • Knowledge of particle collision dynamics
  • Familiarity with physics generators, specifically Pythia
  • Study the production mechanisms of b-bbar pairs in proton-proton collisions
  • Learn about the role of gluons in particle interactions
  • Examine the kinematics of particle production in high-energy physics
  • Explore advanced Feynman diagrams related to b-bbar production
Particle physicists, students in detector physics, and researchers interested in the production mechanisms of heavy quarks at high-energy colliders.
tgessler
I'm giving a report on the LHCb for a detector physics class. I don't quite understand how b-bbar-pairs are produced at the LHCb. LHCb collides two symmetric proton beams and is supposed to work as a b factory.
In many papers concerning the LHCb, for instance
http://arxiv.org/abs/0910.1740v1"
a picure of the b-bbar-production cross section can be found. They all say that most b-bbar-pairs are produced under small or large polar angles, i.e. very close to the beam, thus justifying the forward detector design. It seems that such predictions can be obtained using a physics generator (Pythia) that uses some hadron interaction models. However, I would like to understand, if possible, the angular distribution of the products as a direct result of the p-p interaction, so that I can give a ("handwaving") explanation in my presentation.
Unfortounately, I'm not very firm in theoretical hadron physics. I imagined something like this: A valence quark q from the first proton annihilates with a sea quark qbar from the second photon into a virtual Z0, which then creates a b-bbar-pair. The reason for the b-bbar-pair to move close to the beam in either direction would then be, that the first proton (with the valence quark) contributes much more momentum to the quark pair then the second proton (with the sea quark).
The only Feynman diagram for the b-bbar-production at LHCb that I could find is from page 4 of
http://www.fz-juelich.de/ikp/ghp2009/Talks/talk_ruf_thomas.pdf" .
However, here it seems that both protons simply radiate a gluon, and these then form the b-bbar-pair. This would, however, not explain the mentioned angular distribution.
Is there any remotely easy way to understand this? What is the actual reaction taking place? Is there a simple Feynman diagram for this that I could show?
Thanks in advance.
No. There are three at tree level, all involving gluons, and the next order corrections are at least as large as tree level. It's not simple.
Furthermore, this effect has nothing to do with dynamics - it's purely kinematic. The production is roughly flat in rapidity, which means that there's a strong forward-backward peaking in the lab.
  • · Replies 41 ·
10K
  • · Replies 49 ·
14K
  • · Replies 0 ·
