Time derivative of momentum expectation?
The discussion centers on the time derivative of momentum expectation in quantum mechanics, specifically the equation d
/dt = - as presented on the University of Texas website. Participants clarify the integration by parts technique used to transition between two lines of equation 157. Key insights include the importance of the wavefunction vanishing at infinity and the implications for derivatives of the wavefunction. The conversation concludes with a consensus that both the wavefunction and its derivatives must approach zero at infinity to satisfy quantum mechanical postulates.
  • Understanding of quantum mechanics fundamentals
  • Familiarity with integration by parts technique
  • Knowledge of wavefunctions and their properties
  • Basic grasp of differential operators in quantum mechanics
  • Study the derivation of the time derivative of momentum expectation in quantum mechanics
  • Learn about the Born interpretation of the wavefunction
  • Explore the implications of boundary conditions on wavefunctions
  • Investigate the properties of square-integrable functions in quantum mechanics
Students of quantum mechanics, physicists, and anyone interested in the mathematical foundations of quantum theory and the behavior of wavefunctions.
theneedtoknow
Hello,
I am trying to learn about some basic quantum mechanics.
http://farside.ph.utexas.edu/teaching/qmech/lectures/node35.html this website shows that the time derivative of the momentum expectation d<p>/dt = -<dV/dx>
The part that i am not getting is how the writer goes from the first line of equation 157 on the site, to the second line of the same equation. He simply says he is integrating by parts.
I've tried integrating the 2 terms of the integrand in the first line by parts, but I am not really getting to the second line. I assume that integrating the 2 terms independently should give u1v1 - u2v2 = 0 so that we are left only with the integrals of v1du1 and v2du2(this is judging by the fact that the second line is entirely an integral).
Can someone clear up this step?
Ignore the first term for now and just focus on the second. The trick you're supposed to use is just that if D is the derivative operator and f and g are functions, then fDg=D(fg)-(Df)g. You'll end up with an extra term that doesn't appear in the second line because the integral over it is zero.
Only the second term is integrated by parts, and the resulting total derivative is thrown away. In the first term the factor of (-ih) is swept under the complex conjugation.
EDIT: Fredrik beat me to it... ;)
theneedtoknow said:
Hello,
AFAICS, he is just implicitly using the fact that the wavefunction must vanish at \pm\infty in the derivation. Integration works as follows:
uv = \int vdu + \int udv therefore, for a definite interval, we have
\int^{b}_{a}udv = uv|^{b}_{a} - \int^{b}_{a}vdu, but in this case, uv|^{b}_{a} \rightarrow \psi^{*}\frac{\partial\psi}{\partial t}|^{+\infty}_{-\infty} = 0, so only the vdu integral remains, as shown in the derivation.
P.S. Sorry for the crummy TeX formatting .. I am still learning it, and I couldn't figure out how to make the "evaluation bar" immediately to the right of the uv terms any bigger
EDIT: Yeah me too, but at least we all said the same thing :smile:
Thank you guys!
So, in the first term then, he is just using (ih)* = -ih and dPsi*/dt = (dPsi/dt)*, to combine both terms in the brackets?
theneedtoknow said:
Thank you guys!
Yup!
:) All clear now! Thanks again!
One more question... if I'm evaluationg dPsi/dx at inf or at -inf, it should be zero right? It makes sense that the only way for Psi to go to zero at inf/-inf is if the slope of psi (dPsi/dx)also goes to zero? (the tangent to psi approaches being parallel to the x-axis?)
Yes, psi and all of its position-space derivatives must go smoothly to zero at +/- infinity. This is required by one of the postulates of Q.M. ... which says that the square-modulus of the wavefunction in any volume element is proportional to the probability of observing the particle in that volume element (the Born interpretation of the wavefunction). This means that the wavefunction must be square integrable, i.e. that the square modulus of the wavefunction integrated over all space yields a finite number.
