How to find the mechanism on differential gene expression
The discussion revolves around the mechanisms of differential gene expression between two cell lines, A and B, focusing on the role of transcription factors and promoter activity. Participants explore methods to identify transcription factors that regulate gene expression based on experimental findings and computational predictions.
  • One participant describes research showing high expression of a gene in A cell line and no expression in B cell line, with a specific 250 bp segment of the promoter linked to this activity.
  • Another participant questions the methodology used to determine the activity of the promoter segment in the A cell line.
  • A participant explains that they cloned various lengths of the promoter and linked them to a luciferase reporter gene, finding that segments of 250 bp or longer exhibited high activity in A but none in B.
  • Some participants suggest using computational approaches to identify candidate transcription factors by searching for potential binding sites within the 250 bp sequence.
  • Another participant mentions a biochemical approach involving chromatin immunoprecipitation (ChIP) to characterize proteins bound to the DNA.
  • A participant reports using two prediction programs to identify 48 transcription factors that could bind to the DNA sequence, expressing concern about the potential influence of cofactors that do not directly bind to the promoter.
Participants generally agree on the utility of both computational and biochemical approaches to identify transcription factors, but there is no consensus on the best method or the implications of potential cofactors affecting gene expression.
Limitations include the specificity of the binding predictions and the potential influence of additional regulatory elements or cofactors that may not be directly assessed in the current approaches.
redhawk421001
We have been doing research on the differential expression of one gene between two cell lines (A and B cell lines), with high expression in A cell line and no expression in B cell line. We found that ~250 bp in the promoter of the gene has its activity in A cell line, but no activity in B cell line. So we think the differential profiling of transcriptional factors between A band B cell lines decide whether the gene is expressed. However, I don’t know to find the transcriptional factors regulating the expression of the gene. Please give me some suggestions.
Biology news on Phys.org
What do you mean with that "250 bp of the promoter of the gene has its activity in A cell line"? How did you determine that?
We cloned different length segments of the promoter, and linked the segments to luciferase reporter gene in expression vector, and transfected the vectors into A and B cell lines. Finally, we found that the segments with the length of >=250 bp have high activity in A cell line and no activity in B cell line.
You could use a computational approach to narrow your approach and/or identify candidate transcription factors. Many classes of transcription factors have certain sequence binding preferences. You'd probably be able to find a program somewhere where you can input a DNA sequence and it looks for potential transcription factor binding sites (for example, here is one such program: http://the_brain.bwh.harvard.edu/uniprobe/index.php).
As Ygggdrasil suggests, you can try the bioinformatics approach to see whether there is a consensus TF binding site in the 250 bp sequence. Just search google or the literature for some good prediction programs.
The biochemical approach would be to crosslink the bound TFs to the DNA, perform a chromatin IP (ChIP) and characterize the proteins that are pulled down. For instance: http://www.ncbi.nlm.nih.gov/pubmed/12054904
We have used two programs to predict the transcription factor binding sites with setting the similarity score as 85%, and found that 48 TFs can bind to the DNA sequence. Theremore, we worry whether there are other cofactor not directly binding to the promoter, that affect the expression of the gene.
