Elevator decelerating down vs accelerating up
The discussion revolves around the forces acting on an elevator cable during two different scenarios: one where the elevator is decelerating downward and another where it is accelerating upward. The original poster expresses curiosity about whether the tension in the cable (FT) would be the same in both cases, specifically when decelerating at -3 m/s² versus accelerating at 3 m/s².
  • The original poster attempts to analyze the tension in the cable using equations for both upward and downward motion, questioning the implications of acceleration signs on the tension values. Some participants suggest that the choice of positive and negative directions must be consistent in the equations used.
The discussion is ongoing, with participants exploring the implications of different acceleration signs and their effects on the tension in the cable. Some guidance has been offered regarding the importance of consistent directional conventions in the equations.
The original poster notes that their class problems have primarily involved upward motion, which may influence their understanding of the downward acceleration scenario. There is also mention of confusion regarding the signs of acceleration and their impact on the calculations.
Ralph777
This is not an actual problem from my class. All our problems involved an elevator going upward (both accelerating and decelerating). But I am curious if an elevator cable would have the same FT if the elevator was decelerating downward at -3 m/s2 as it would accelerating upward at 3 m/s2 ? I am having a hard time conceptualizing why that is true in my mind's eye.
Elevator Up: FT - mg = ma
so: FT = m (a + g)
so I figure that:
@ a<0 FT< FG
@ a=0 FT= FG
@ a>0 FT > 0
I was curious what the values are when the elevator is going down.
I used this equation: mg - FT = ma
so: FT = m ( g - a )
so I figure that:
@ a<0 FT> FG
@ a=0 FT= FG
@ a>0 FT< FG
Is it true that an elevator cable would have the same FT if the elevator was decelerating downward at -3 m/s2 as it would accelerating upward at 3 m/s2 ? I am having a hard time conceptualizing why that is true in my mind's eye.
Thanks
so: FT = m (a + g)
so I figure that:
@ a<0 FT< FG
@ a=0 FT= FG
@ a>0 FT > 0
so I figure that:
@ a<0 FT> FG
@ a=0 FT= FG
@ a>0 FT< FG
Thanks
you let the plus and minus sign sting you (it happens quite often)!
In your second set of equations for the downward acceleration, you assumed that the downward direction was positive (g is positive), and therefore, the downward acceleration is positive. Thus, FT is less than the elevator weight in this case, and greater than the elevator weight in the first case. Draw a sketch, and look at it over and over and over again, and don't let that minus sign bite you any more:mad:
Thanks for the help.
any advice or solution? showthread.php?t=612910
Elevator Up: FT - mg = ma Up positive
so: FT = m (a + g)
so I figure that:
@ a<0 FT< FG
@ a=0 FT= FG
@ a>0 FT > 0
I used this equation: mg - FT = ma Down positive
so I figure that:
@ a<0 FT> FG
@ a=0 FT= FG
@ a>0 FT< FG
Thanks
If you want to compare, the convention of positive or negative direction must be consistent.
  • · Replies 31 ·
12K
