What was the initial velocity of the car?
The discussion revolves around calculating the initial velocity of a car involved in a traffic accident, using the length of skid marks, the mass of the car, and the coefficient of friction. The problem involves applying principles of physics related to forces, friction, and motion.
  • Homework-related
  • One participant presents the scenario of a car with a mass of 1250 kg that skidded for 24.9 m, seeking help to find its initial velocity.
  • Another participant suggests calculating the gravitational force, normal force, frictional force, and then using these to find acceleration and initial velocity.
  • Several participants express confusion about summing forces, specifically whether to consider vertical or horizontal forces, and seek clarification on vector addition.
  • One participant provides detailed calculations for gravitational force, normal force, and frictional force, but struggles with vector addition to determine net force and acceleration.
  • Another participant reiterates the need to identify forces with their magnitudes and directions to correctly apply Newton's second law.
  • A later reply indicates that the participant feels more confident about the relationship between net force and acceleration after receiving assistance.
Participants generally agree on the approach to solving the problem using physics principles, but there is uncertainty regarding the correct application of vector addition and force summation. The discussion remains unresolved as participants continue to seek clarification on these points.
Participants have not reached a consensus on the specific steps to take in summing forces or determining acceleration, indicating potential gaps in understanding vector quantities and their application in this context.
Schu
It's been a while since I have gone through my physics classes so help me out if you would.
While investigating a traffic accident we found skid marks that were 24.9 m in length. The mass of the car was around 1250 kg. After the accident reconstructionist used his "sled" the coefficient of friction was 0.836. What was the initial velocity of the car?
From what I remember if unknown variable such as the time or acceleration would make this problem easy. Hopefully I will be able to go to the reconstructionist school and learn the things specific to accidents.
I'm not sure how to go about finding the velocity. Can anyone help?
:confused:
You have the mass of the car. You can figure out the gravitational force. You can then figure out the normal force on the car. You can then figure out the frictional force, then the acceleration. You have the final velocity of the car and the distance travelled. Now, you can figure out the initial velocity.
gravitational force = mass * gravity
normal force = gravitational force
friction force = coefficient of friction * Normal Force
sum of the forces = mass * acceleration?? What forces do you add up, the vertical or the horizontal or both? I had gone down this road but this last part confused me.
If you know what forces are acting on the body, and know how to add vectors together, you should be fine. Tell us the forces you believe to be acting on the body in question, including magnitude and direction. In fact, if you can do that step but don't know how to sum those forces, then let us know that that is the problem, and perhaps you just need a quick reminder on vector addition.
The car was moving on a level plane in a straight direction which would be a 0 degree direction if looking on an x,y grid. The mass of the car is 1250 kg. It took the car 24.9 m to stop. The final velocity is 0 m/s the coefficient of friction was 0.836.
See if I am making any sense.
Gravitational force
1250 * (-9.81) = (-12262.5) N
Normal Force since Fg + Fn = 0
12262.5 N
Friction Force Ff= coef of friction * Fn
0.836 * 12262.5 = 10251.45N
Now I have problem adding the vectors to get the sum of the forces which prevents me from getting the acceleration. Which vectors do I add so I can put it in the Sum of FOrces = mass * acccel
Gravitational force
12262.5 N
Vector quantities require a direction. I believe I asked if you could list the forces involved with magnitude and direction.
[tex]\vec{F}_G = mg [down][/tex]
[tex]\vec{F}_N = mg [up][/tex]
[tex]\vec{F}_{fr} = \mu |\vec{F_N}| [back][/tex]
[tex]\vec{F}_{net} = \vec{F}_G + \vec{F}_N + \vec{F}_{fr}[/tex]
[tex]= mg [down] + mg [up] + \mu mg [back][/tex]
[tex]= mg [down] - mg [down] + \mu mg [back][/tex]
[tex]= \mu mg [back][/tex]​
I'm sure you understand why [itex]mg [up] = -mg [down][/itex]. So, now I've given you [itex]\vec{F}_{net}[/itex], can you get the rest?
I think I am all set now. The F net = m*a correct? THen a = Sum F / m
Thanks for the help.
  • · Replies 60 ·
