Thread Closed
derivative of an inverse trig function
Share Thread Thread Tools
Feb12-10, 04:08 PM   #1
[tex]y=sec^{-1}\frac{1}{t}, 0<t<1[/tex]
2. Relevant equations
[tex]\frac{d}{dx}sec^{-1} x= \frac{1}{\left|x\right|\cdot\sqrt{x^{2}-1}}[/tex]
3. The attempt at a solution
Basically to simplify things I used u substitution so I let u=1/t then du/dt=-1/t2 and I got:
[tex]y=sec^{-1}u\rightarrow y^{,}=\frac{1}{\left|u\right|\cdot\sqrt{u^{2}-1}}\cdot\frac{du}{dt}[/tex]
which,when I substituted for u, I got:
[tex]=\frac{1}{\left|\frac{1}{t}\right|\cdot\sqrt{\left(\frac{1}{t}\right)^{ 2}-1}}\cdot\frac{-1}{t^{2}}[/tex]
which works out as:
[tex]=\frac{-1}{\left|\frac{1}{t}\right|\cdot t^{2}\cdot\sqrt{\frac{1^{2}}{t^{2}}-1}}[/tex]
and:
[tex]=\frac{-1}{t\cdot\sqrt{1-t^{2}}}[/tex]
however, the answer as per the back of the book is:
[tex]\frac{-1}{\sqrt{1-t^{2}}}[/tex]
what did I do wrong???
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb12-10, 04:19 PM   #2
The step,
[tex]\frac{-1}{\left|\frac{1}{t}\right|\cdot t^{2}\cdot\sqrt{\frac{1^{2}}{t^{2}}-1}} = \frac{-1}{t\cdot\sqrt{1-t^{2}}}[/tex]
is incorrect. Remember
[tex]a\sqrt{b} = \sqrt{a^2b}[/tex]
so you have,
[tex]t\sqrt{1/t^2-1} = \sqrt{1-t^2}[/tex]
Feb12-10, 04:24 PM   #3
ooooooooh ok. that makes more sense. thats clever hehehe
thank you so much
Feb12-10, 05:21 PM   #4
Recognitions:
Homework Helper Homework Help
For next time, you may remember that since [tex]\cos x = \frac{1}{\sec x}[/tex], it is true that [tex]\sec^{-1} \left(\frac{1}{x}\right) = \cos^{-1} x[/tex] and so the derivative is standard.
Thread Closed
Thread Tools
Similar Threads for: derivative of an inverse trig function
Thread Forum Replies
Another inverse trig function Calculus & Beyond Homework 1
Derivative of inverse trig function Calculus & Beyond Homework 12
Inverse Trig function derivative Calculus & Beyond Homework 2
derivative of inverse trig function Calculus & Beyond Homework 3
Inverse trig derivative Calculus & Beyond Homework 1
