| New Reply |
Simple Diode Problem |
Share Thread | Thread Tools |
| Feb12-10, 09:11 PM | #1 |
You have a series circuit consisting of a dc power supply, a 90 ohm resistor and a diode. If the measured current in the circuit is 136 mA, and the saturation current for the diode is 0.006 mA, what is the voltage drop across the diode? Assume the diode temperature is 300 K. Your answer should be given to three places after the decimal point. 2. Relevant equations [tex]I = I_{o}(e^{\frac{qV}{k_{b}T}}-1)[/tex] [tex] q = 1.602x10^{-19}[/tex] [tex]k_{b} = 1.38x10^{-23}[/tex] 3. The attempt at a solution Rearranging the above the equation I get [tex]\frac{k_{b}T}{q}ln(\frac{I}{I_{o}} + 1) = V[/tex] Plugging in the numbers I get 0.259V which isn't the right answer, I know this problem isn't difficult but I can't seem to wrap my head around why this doesn't work. |
| Feb12-10, 09:20 PM | #2 |
Mentor
| Feb12-10, 09:27 PM | #3 |
| Feb12-10, 09:51 PM | #4 |
Mentor
| Feb12-10, 11:38 PM | #5 |
no I formulated my equation from the correct expression, I just mistyped it in the original post
| Feb13-10, 01:31 AM | #6 |
Recognitions:
Your result is correct.
ehild |
| Feb13-10, 08:26 AM | #7 |
Well that sucks, the problem is in an online assignment and it only accepts the right answer (we get 3 tries at it). It won't accept that one.
| Feb13-10, 09:18 AM | #8 |
Recognitions:
Interesting that it gives the resistance of a series resistor and does not use its value in the question. Maybe, they wanted to ask the emf of the source.
ehild |
| Feb13-10, 09:24 AM | #9 |
What is the voltage across the diode-resistor combination? |
| Feb13-10, 05:30 PM | #10 |
Mentor
I have a few ideas about what might be wrong.
1. 0.006 mA seems pretty large for a diode saturation current. I think nA or pA range is more reasonable. Do they really say 0.006 mA, or could it have been 0.006 μA? Or something else? 2. Perhaps there are too many significant figures in the answer "0.259 V". Try the calculation using saturation currents of 0.0055 and 0.0065 mA, to get a sense of how many sig figs are justified. 3. Shouldn't the diode equation include an extra material-dependent ideality factor in the qV/kT term? Perhaps they expect the student to know what it should be, so they didn't provide the value in the problem statement. |
| Feb13-10, 05:42 PM | #11 |
| Feb13-10, 05:52 PM | #12 |
Mentor
Okay, sounds like those were three dead ends. Oh well, sorry.
| Feb13-10, 05:54 PM | #13 |
thanks anyways, I guess I'll just have to forget about it.
| Feb13-11, 10:03 AM | #14 |
You are doing it right, I had the same question but different values:
120 ohm resistor, current in the circuit (I) = 73mA, saturation current (Io) = 0.010mA, and T=300K. My answer came out to be 0.230V which was accepted as correct. Just try it again and make sure all your calculations are correct. |
| Feb13-11, 10:05 AM | #15 |
I'm not sure how to get the second part:
What is the voltage across the diode-resistor combination? Any ideas? |
| Feb13-11, 10:24 AM | #16 |
Recognitions:
| Feb13-11, 10:37 AM | #17 |
Ahh...yes. I had put in Vr-Vd.
Vd + Vr worked, I got 8.99V/ Thanks! |
| New Reply |
| Thread Tools | |
Similar Threads for: Simple Diode Problem
| Simple diode questions | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Simple Derivation Of Diode Equation | Classical Physics | 5 | ||
| Simple Diode Problem | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Simple Diode Circuit... | Electrical Engineering | 4 | ||
| Simple Diode and Capacitor question | Engineering, Comp Sci, & Technology Homework | 7 | ||
