Multiplying Vectors: Solving a.b = (a x db/dt) + (da/dt x b)
  • Thread starter Thread starter Preciouspearl
    Vectors
The discussion focuses on proving the identity d/dt (a.b) = (a x db/dt) + (da/dt x b) using the vectors a = t^2 i - (4-t)j and b = i + t j. Participants clarify that the inner product (dot product) and vector product (cross product) are distinct operations. The inner product is calculated by multiplying vector components and summing the results, while the vector product results in a new vector. The proof requires only the dot product, leading to the conclusion that d/dt(a.b) = a.(db/dt) + b.(da/dt).
  • Understanding of vector operations, specifically dot and cross products.
  • Familiarity with differentiation in the context of vector calculus.
  • Knowledge of three-dimensional vector representation.
  • Basic algebraic manipulation skills for vector components.
  • Study the properties and applications of the dot product in vector calculus.
  • Learn the rules for calculating the cross product of vectors in three dimensions.
  • Explore differentiation techniques for vector functions over time.
  • Practice solving vector calculus problems involving both dot and cross products.
Students and professionals in mathematics, physics, and engineering who are working with vector calculus and need to understand vector operations and their applications in differentiation.
Preciouspearl
If a = t^2 i - (4-t)j
and b = i + t j
show d/dt (a.b) = (a x db/dt) + (da/dt x b)I know you have to multiply the vectors a and b
then do da/dt
then db/dt
and times db/dt with a
and times da/dt with b
that should be the proof
However, I don't know how to multiply the vectors!
Can someone please tell me how to multiply them
Thank you, in advance
There are two products defined over three dimensional vectors.
First is the inner (\dot\scalar) product, that for any a=(a1,a2,a3), b=(b1,b2,b3)
Gives
a.b=a1*b1+a2*b2+a3*b3.
Which means, multiply the vector component-wise and then sum up the results. This product gives a number!
The second is the vector (\cross) product
which is:
[tex]\vec{a} X \vec{b}=(a_{2}b_{3}-b_{2}a_{3})\hat{i}+(a_{3}b_{1}-a_{1}b_{3})\hat{j}+(a_{1}b_{2}-a_{2}b_{1})\hat{k}[/tex]
The result is a vector!
Now please be careful. The identity which you are trying to prove involves only dot products. So it's:
[tex]\frac{d}{dt}(\vec{a}.\vec{b})=\vec{a}.\frac{d}{dt}\vec{b}+\vec{b}.\frac{d}{dt}\vec{a}[/tex]
