Why Even Talk About Gravitons Even Existing?
  • Context: Graduate
  • Thread starter Thread starter NYSportsguy
    even Gravitons
The discussion revolves around the existence and relevance of gravitons in the context of gravity as a fundamental force. Participants explore the nature of gravity compared to the other fundamental forces, the implications of quantum mechanics, and the challenges in detecting gravitons. The conversation touches on theoretical, conceptual, and speculative aspects of gravitational interactions.
  • Some participants argue that gravity is significantly weaker than the other fundamental forces at atomic scales, suggesting it operates primarily at larger mass levels.
  • Others propose that the existence of gravitons is hypothesized due to the success of quantum field theory in modeling other forces, despite the challenges in detecting them.
  • A participant questions the necessity of discussing gravitons if gravity is fundamentally different from the other forces, which utilize force carriers like bosons.
  • Some participants assert that all particles with mass experience gravitational effects, regardless of their size, challenging the notion that gravity only manifests at larger scales.
  • There are references to alternative theories regarding the source of mass and inertia, including the Higgs field and electromagnetic sources, suggesting a divergence in understanding mass's relationship with gravity.
  • Concerns are raised about the implications of gravity on light and its interaction with spacetime, questioning the assertion that gravity only affects larger masses.
  • Some participants express skepticism about the need for quantum gravity, arguing that the existence of gravitons is not a necessity.
Participants express multiple competing views regarding the nature of gravity, the relevance of gravitons, and the relationship between gravity and the other fundamental forces. The discussion remains unresolved, with no consensus on the necessity or implications of gravitons.
Participants highlight the challenges in detecting gravitons due to their weak interaction with matter and the theoretical implications of gravity's behavior at different scales. There are also references to unresolved questions about the nature of mass and its connection to gravitational effects.
NYSportsguy
From what I have read out there, of the four fundamental forces that have been detected in our universe, gravity seems to be the weakest at the atomic level and smaller.
I figure this is most likely true because at the atomic level and smaller - the weak and strong forces (those causing beta decay and gluons to hold quarks inside of protons and neutrons) are the forces that build matter at an atomic level.
Gravity seems to only rear it's head when the mass of any object is that of an atomic mass or higher. The larger the mass of anything...the more gravity plays a role according to Einstein's general relativity principles.
Therefore gravity is a force that needs to be separated from the other three major forces because it doesn't seem to appear or work at levels smaller than anything smaller than an atom.
If this is all true...then why the need to even talk about mass-less particles like gravitons even existing in the first place? After all, Einsteins' Gen. Relativity Theory says gravity is nothing more than the physical bending or curving of the space-time fabric which anything that has mass on it does. Thus it's nothing more than a force that only shows up when masses are that of an atom or larger and not at the quantum level.
Astronomy news on Phys.org
Gravitons are hypothesized because of the overwhelming success quantum field theory has enjoyed using bosons to model the behavior of the other three fundamental forces of nature [EM and the nuclear forces]. Detection of individual gravitons is, however, virtually impossible due to the extremely low cross section for the interaction of gravitons with matter. It has been estimated that a detector the size of Jupiter orbiting a neutron star, would only detect a graviton once every 10 years under ideal conditions. Gravitional waves, composed of many gravitons, are detectable. There is little doubt of the existence of gravitational waves. Hulse received the 1993 nobel prize for the indirect detection of gravitational waves.
Negative, all quantum particles with mass in the Standard Model experience gravitation, which are smaller than a nucleus, the only requirement is mass.
It is only that the gravitational interaction strength is several orders of magnitude weaker than the other forces at this scale, making it extremely difficult to detect.
[/Color]
Mass in itself is a serious problem. It only manifests through inertia and gravitational effect.
yet we are told that mass is bestowed by a Higgs field.
So the Higgs is the source of inertia and gravitation ?
The three amigos Haisch, Rueda and Puthoff produced a paper some years ago that implied that inertia had an electromagnetic source.
I'm not pushing their barrow, but it seems much more likely than the Higgs hypothesis.
The Higgs MECHANISM would be the source of mass, Higgs boson or no.
EDIT: you said... "Thus it's nothing more than a force that only shows up when masses are that of an atom or larger and not at the quantum level. "
Wow... light must feel REALLY silly following geodesics right into the throat of a Black Hole when it must be immune to gravity. In fact, all particles should. IN FACT, let's just tell all nuclear fusion in the universe to stop right now.
Light doesn't cause gravity to occur because it is mass-less. A black hole (being extremely massive) causes the light to get sucked into it...not sure what your example is trying to say. If anything it further strengthens my QUOTE...not weakens it.
Light doesn't cause gravity? In other words, light doesn't contribute to warping spacetime through the SET? So what? You haven't adressed how light can be subject to gravitational forces and must fullow spacetime geodesics if gravity 'only shows up when masses are that of an atom or larger and not at the quantum level'. Before you riposte, how about answering the original question?
EDIT: Do some research on 'scalar fields' for the mass issue.
Edit2: While you're at it, "Why Even Talk About Gravitons Even Existing?" is just eggregious. Spelling errors are nothing, and grammar in a post means little, but have some respect for your topic headers. :smile:
In my opinion it seems a bit far-fetched to link gravity to the other three major fundamental forces considering the other three are all strong at the atomic and smaller levels while gravity usually only rears it's head at large mass levels. The other three forces use "force fields" of some kind to attract and repel things while gravity really doesn't use any type of "force field" but rather is just physically bending space-time as we know it.
This explains why electromagnetism uses photons to carry its attracting and repelling powers, while the strong force uses gluons for it's attracting powers and the weak nuclear force uses W and Z bosons for it's functions.
Gravity, on the other hand hand, shouldn't have it's own similar particles like the graviton just for the sake of fitting in with the other three quantum forces.
Yes... hence the great divide between SR/GR and QM. Hence the need for Quantum Gravity. Gravitons are one possiblity and hardly the only accepted one. Oh, and since when has 'shouldn't' or 'should' played a role in what 'IS'?
There is no "need" for quantum gravity. That's exactly the point I am trying to make. Why should there be a "NEED" for quantum gravity like you said above?
If gravity has no effect at the quantum level (objects with extraordinary small masses)...why try to unite it with the other three fundamental quantum forces to begin with?
It sounds to me like quantum physicists are chasing after a "boogey man" to me.
Seriously dude...I really don't think you know what you're talking about. You got lost somewhere and now just seem bitter for no reason. Try sticking to the question I asked, why I posed the question and the information that lead me to ask this question. If you can't come up with an answer or participate constructively to the conversation...just go somewhere else.
It might be a bit premature to dismiss gravitions. The Hulse study makes a very strong case for the existence of gravitational waves, and waves without a corresponding boson would be clearly ATM proposition. Direct detection of gravity waves [the purpose of LIGO] would be huge step forward. It would effectively end any controversy over the existence of gravitons and constrain their properties.
Hi Chronos,
Could you go over your statement again..."The Hulse study makes a very strong case for the existence of gravitational waves, and waves without a corresponding boson would be clearly ATM proposition."
What is an ATM proposition mean?
NYSportsguy said:
Hi Chronos,
Well, either Chronos is in love with an Automatic Teller Machine and wan't to propose to it... or he means, "At The Moment".
I.E. A placekeeper theory to make progress with while more complete and accurate theories are developed.
Apologies, ATM = against the mainstream.
ATM means "against the mainstream". Discussion of ATM propositions is strongly discouraged here at PF, for good reasons.
NYSportsguy, gravity is equally weak on all scales. There are some therories that postulate it could be stronger at small distances, but there are no observations to confirm this.
So there's no "threshold scale" where gratvity starts to apply, thus there's no reason to assume that there's no gravity at the "quantum level", as you put it.
Ahhhh... that makes more sense. I still harbor a deep suspicion that you have major issues with Automatic Teller Machines. You love them don't you? *shhh shhh* no crying now... it's ok... Let it all out!
EDIT: Ich: Don't bother. This isn't NYGuy's first whack-a-do thread. In fact, it isn't even his only ACTIVE whack-a-do thread. He just finished posting the Newtonian formula for work out of nowhere in another thread. *cries*. Make the bad man stop.
Just trying to help him out, frame dragger. I hoped pointing out the ATM component of his argument would be instructive. It is easy to wander into the ATM mine field. I view this as an innocent transgression until followed by denial of observational evidence.
Because when you apply straight general relativity to certain situations and ask what happens you get the answer "divide by zero" which is no real answer. Once you compress things past a certain point quantum effects start becoming important, and if you exclude quantum effects from things like black holes, you run into problems with things like the second law of themodynamics breaking down, which is a bad thing.
Basically, if you assume that gravity does not have quantum effects, your theories start giving non-sense results (i.e. divide by zero, infinities, answers that don't make any sense).
But it does.
Here is a cool experiment that illustrates gravity having quantum effects
http://physicsworld.com/cws/article/news/3525
Basically, you create a gravity potential well, trap neutrons in it, and then the neutrons behave the same why as they would in an EM potential well.
Also gravity is weak. It's not non-existent. One of the cooler experiments you can do is the Cavendish experiment where you see gravitation effect of brick sized object.
There is also the Mossbauer effect, which is a standard experiment that shows that yes, gravity does act on particles
http://world.std.com/~sweetser/quaternions/gravity/redshift/redshift.html
That's a observational quirk. Any experiment that has been done at the atomic and subatomic levels shows gravity working there too.
That's just a function of the way that we do the math and probably not a result of the nature of the forces themselves. It so happens that if you really want to, you can show that classical electromagnetism can be modeled as the bending of space-time in 5 dimensional space (which is what Kaluza figured out in the 1920's).
The problem with having two independent and separate theories is that you then have to explain exactly what happens at the boundary of those theories.
Hmmm... you're a much better person than I am, or at least a hell of a lot less negative. Maybe you're right... it's just frusterating trying to communicate past the pseudoscience out there sometimes.
I don't know who said it earlier, I think it was NY-sports but, one of the reasons why gravity should be omitted and separated from The Strong & Electroweak forces was because it has no force field. Well... the thing about that is... the boson fields that the other forces operate in, are "imbedded" in the space-time which is what gravity is, moving or hence curving warping space-time, I think maybe gravity should not be omitted since the other gauge boson fields operate within the space time, gravity is actually the harboring force, enabling the other forces, it's the housing force. Gravitons? Well... I don't think they should be dismissed too fast, I think there must be some merit in quantum gravity theory
...but if gravitons DO exist then gravity IS a force field! That's the problem with unifying that notion with your description of GR spacetime. I think it's a good argument for a theory unifying the two being radically different from current theories. Trying to reconcile the two now, requires unreasonable contortions.
I don't have a problem with thinking of gravity as spacetime deformation instead of a "force" field, and of gravitons as the quanta of spacetime deformations. The point is that we don't have a theory that works that way. Or any other way, for that matter.
Just a small problem there. :wink: Maybe within our lifetimes we'll see it.
Yea way to add intelligent insight into the conversation there buddy.
To the rest of you, thank you very much for your answers and links for examples. I will look over all of your responses and the links you have provided me and see if I can retort and/or understand better the topic.
How can you NOT have a problem with this? There is nothing to prove or suggest that this is the right way to look at gravity at all. Why are you comparing they way light works and behaves to the concept of gravity? Possibly because E = MC^2?
Still not a good enough reason...I am sure you have another but I would like to hear it.PS - Your earlier statement seems to be correct. Anything with any mass (no matter how tiny or miniscule by our standards) will exert some sort of curvature on space-time (hence gravity at an atomic level).
Link: https://www.physicsforums.com/archive/index.php/t-118327.html
Maybe I'm rather the uncomplaining type of guy?
There is nothing to prove it, but the theoretical analysis of gravitational waves in the weak field limit suggests that it's associated with a massless spin-2 particle.
No, because both follow a wave equation (I'm talking about gravitational radiation here), and QM tells us how to quantize waves. But it doesn't tell us how to quantize the full-fledged nonlinear theory.
I'm stuck on the wave thing. It is difficult to conceptualize gravitational waves without bosons - sort of like an ocean wave without water molecules. Bosons may not be an ideal explanation, but it works for all the other fundamental forces. An effective theory is not necessarily a bad thing. Why it works - that is for our children to solve.
  • · Replies 37 ·
  • · Replies 20 ·
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 19 ·
