Projectile Motion Help - Find Angle of Elevation for Rajesh
  • Thread starter Thread starter rajesh.msen
    Projectile
The discussion revolves around a problem in projectile motion, specifically focusing on determining the angle of elevation needed for a projectile to reach a designated landing point from a higher launch point. The original poster, Rajesh, mentions having specific parameters such as the launch and landing points and a variable speed for the projectile, but expresses uncertainty in the mathematical aspects of the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants suggest breaking down the problem into x and y components of motion, using constant acceleration equations, and eliminating time to find an equation for the angle θ. Rajesh expresses confusion about the recommendations and seeks clarification on which resources or methods might be most effective for solving his equations.
The discussion is ongoing, with participants providing guidance on how to approach the problem mathematically. Rajesh is actively seeking further clarification and direction on the best methods to apply, indicating that there is no explicit consensus yet on a single approach.
Rajesh notes that he is new to physics and struggles with the mathematical aspects, which may affect his ability to follow the suggested methods. There is also mention of external resources that have been recommended, but Rajesh is unsure which to prioritize.
rajesh.msen
Hi to all,
I have a problem in projectile motion.I need the angle of elevation.I know the launch point its greater than the target,I know the destination point where it should land,i know the speed it travels(its option for users to select the speed between (60 - 100),I need the angle of elevation to reach the destination point.
Ex : Angle of elevation differs based on the value of the variable speed.I not good in maths and very new to physics.Any one help me to solve this problem.Even tell me if the solution is not exit.
Help me guys.Thanks in advance.
---Rajesh---
velocity,launch_point,landing_point
Welcome to PF!
Hi Rajesh! Welcome to PF! :wink:
Write equations for the x and y components separately.
For x, remember that the x component of velocity is constant.
For y, use the standard constant acceleration equations. :smile:
Hi Rajesh! :smile:
(btw, no need to PM me … everyone gets automatic email notification of any reply to a thread that they've contributed to :wink:)
The question gives you vi (but not its direction), and x and y.
So call the time t, and call the direction θ, so that the initial components of velocity are vicosθ horizontally and visinθ vertically.
Then use the standard constant acceleration equations for the horizontal direction (a = 0) and the vertical direction (a = -g) separately: that gives you two equations, from which you can eliminate t, so you get one equation for θ. :smile:
