Why is the torsional constant of a wire inversely related to its length?
  • Thread starter Thread starter yokan
    Constant
The torsional constant of a wire is inversely related to its length, as demonstrated through the rotational version of Hooke's law, expressed as τ = k * θ. When considering a wire of length L, the torque τ required to achieve a twist θ is directly proportional to the torsional constant k. If the length of the wire is doubled to 2L, the same angular twist θ requires only half the torque, resulting in a torsional constant that is half of that of the original wire. This relationship mirrors the behavior of springs in series, where the effective spring constant is also halved.
  • Understanding of torsional pendulums
  • Familiarity with Hooke's law in rotational dynamics
  • Basic knowledge of torque and angular displacement
  • Concept of composite systems in mechanics
  • Study the principles of torsional pendulums and their applications
  • Explore the derivation and implications of the rotational version of Hooke's law
  • Investigate the behavior of springs in series and their effective spring constants
  • Examine real-world applications of torsional constants in engineering and materials science
Students and professionals in physics, mechanical engineering, and materials science who seek to understand the mechanics of torsional systems and their practical applications.
yokan
I came to find out through books and actual experiment that the torsional constant of a wire in a torsional pendulum is directly inverse to its length
I find the torsional constant using the rotational version of hooke's law, t=k*theta.
I have always thought that a greater length should give a greater torque (thus a higher torsional constant) because it has a higher momentum.
I tried to search for more specific explanations as to why it is a inverse relation on the internet, but without much help. The books I got in the libraries are either too simple or too advaned for me.
Any explanations would be greatly appreciated. Thx!
Think of it like this. The torsional constant is defined as the amount of torque needed to get a certain angular twist: [itex]k = \tau/\theta[/itex]. So assume a given wire of length L has a constant k. It requires a torque [itex]\tau[/itex] to produce a twist of [itex]\theta[/itex]. What if I only needed a twist of [itex]\theta/2[/itex]? Would you agree that I only need half the torque? (I presume you would.)
Now consider a wire of length 2L. You can think of it as being composed of two wires of length L in series. What the torsional constant of this composite wire? If I want a net twist of [itex]\theta[/itex], realize that each half of the wire only gets a twist of [itex]\theta/2[/itex]. Thus the same twist ([itex]\theta[/itex]) requires only half the torque. Thus the net torsional constant of a wire of length 2L is 1/2 the constant of a wire of length L. Make sense?
Note that this is the same thing that happens with springs put in series. Say I have two springs of spring constant k. If I hook them in series, what's the spring constant of the composite double spring? Figure it out the same way as I did above and you'll find that the double spring has a spring constant of k/2.
Thx a lot for you help, I got the hang of it now
21K
13K
12K
