Thread Closed
Ionization chamber and GM tube
Share Thread
Feb15-10, 10:44 PM   #1
What are the difference between ionization chamber and GM tube in structure which make them have different functions?
3. The attempt at a solution
Higher voltage is applied to GM tube so that electron avalanche can occur.
Then I wonder that
if higher voltage is applied to ionization chamber, it can function as a GM tube.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb15-10, 11:54 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
In principle, you are right, but read this:
http://en.wikipedia.org/wiki/Ionization_chamber.
ehild
Feb16-10, 06:37 AM   #3
The difference is...
ionization chamber is connected to galvanometer and operate at normal gas pressure
while GM tube is connected to a counter and operate at low pressure
Is it?
Thread Closed
Similar discussions for: Ionization chamber and GM tube
Thread Forum Replies
Long tube headers vs. short tube headers. Mechanical Engineering 8
Difference between ionization chamber and GM tube Introductory Physics Homework 0
precombustion chamber and compression chamber Mechanical Engineering 1
tube in tube heat Xchanger Mechanical Engineering 2
Fixed-Tube-Sheet Shell and tube Heat Exchanger Materials & Chemical Engineering 1
