Uncertainty principle consist with energy conservation?
The discussion centers around the relationship between the uncertainty principle and energy conservation, exploring theoretical implications and interpretations within quantum mechanics. Participants raise questions about how energy can appear to fluctuate in short time intervals and the implications of virtual particles and measurements on energy conservation.
  • One participant questions how the uncertainty principle (dEdt >= h/2) can coexist with energy conservation, suggesting that energy could exceed initial values in short time intervals.
  • Another participant notes that energy conservation can be violated in "virtual" processes, which cannot be observed experimentally, and relates this to Feynman diagrams.
  • A participant expresses confusion about the concept of "the energy available" and whether it is based on theoretical or experimental grounds.
  • Discussion includes the double-slit experiment as an example of how measurement affects quantum systems, with one participant suggesting that any form of observation impacts the outcome.
  • There is a mention of Schrödinger's cat problem in relation to observation and wavefunction collapse, indicating the complexity of measurement in quantum mechanics.
  • Some participants discuss the limitations of human observation in tracking quantum particles, emphasizing the probabilistic nature of quantum mechanics.
Participants express differing views on the interpretation of energy conservation and the implications of the uncertainty principle. There is no consensus on whether energy conservation can be considered violated or merely unobservable in certain contexts.
Limitations in understanding arise from the dependence on definitions of energy and the nature of virtual particles, as well as the unresolved complexities of quantum measurement and observation.
This discussion may be of interest to students and enthusiasts of quantum mechanics, particularly those exploring the nuances of the uncertainty principle and energy conservation in theoretical contexts.
luxiaolei
Hi,all, can anyone help to understand how uncertainty principle consist with energy conservation?
dEdt >= h/2, then in a short time interval, the energy can be really large, even the previous state has lower energy? I can't really understand this..
say, particle A appeared at t=0 (at rest) and it has life time 10^-15 s and it has initial energy E1 (use E=mc^2), then is that mean at t>0, its energy could growths up?bigger than E1? Then the energy care not conserved..
Thanks in advance!
The interpretation of this uncertainty is NOT the same as that of x and p, because time is not an operator. See for instance Griffith's QM textbook. The point is, that if you want to talk about energy conservation, you have to know the exact amount of energy available.
I never really understood how virtual particles are justified with merely this "dE*dt>constant" idea and without quantum field theory. But you see it a lot in textbooks, so if anyone knows how to justify this idea, I'm very curious! :)
Thanks haushofer for replay. I can not really understand ''the energy available'', is that based on theoretical or experimental? a bit confusing there, thanks for explan:)
Hi luxiaolei!
Energy conservation can be indeed violated, but one cannot observe such processes experimentally. Processes which violate energy conservation (so-called "off-shell" processes) are "virtual". They appear in the internal structure of Feynman diagrams. Experimentally one can only observe the external lines, which correspond to observable particles.
Think for example of the double-slit experiment.
If you measure through which of the holes the particle passes, there's no interference pattern to observe. You destroyed the quantum mechanical uncertainty - your measurement is a physical process interacting with the particle.
Instead, if you do not measure through which of the holes the particle goes, you observe the interference pattern! In this case there is quantum mechanical uncertainty, and in the theoretical description both possibilties are taken into account. Both ways (particle goes through hole 1 OR goes through hole 2) are weighted in some way with their probability, without taking care what "really happens" or how to interpret it, so far. What "really happens" is virtual, you dannot measure it without destroying the interference pattern. The same happens in those Feynman diagrams. All possible ways (internal virtual structures) are weighted with their quantum mechanical probability. And energy conservation has not to be fullfilled by virtual, non-observable processes.
Martin
Hi Sunset:
Thanks a lot for the replay, very good explanation, got what I wanted! although I would die for knowing why observer can affect experiment result.
Hi luxiaolei!
You're welcome.
Maybe a word on that issue. Of course one cannot observe the particles by staring at them with one's eyes. Nobody saw an electron with his bare eye. In order to observe an electron one has to be more rude: one has to shoot other particles on it. From the scattering one obtains informations about the electron. And here we are - only if we let something interact with the electron we can observe it. No need to die so early ;)
Martin
Hi Sunset:
actually I haven't done double slits experiment, I am wonder even if I did not affect the experiment, just ''observe'' it(the electron goes which hole), say I am a superman and I can track how electron move with my eye(I really hope so), will the pattern still appear? or more abstractly, mean by ''observe'' can be even just known it.
I think this question can trace back to Schrödinger's cat problem, any kind of observe will affect the wavefunction collapse.
I am sorry, I might just be silly, I am a level3 undergraduate student, confusing about everything...
That's the point. You cannot track with your human eye how the electron moves. We humans only know a probability (the square of the electron wave function) where to find the electron in a position measurement. You cannot observe momentum and position simultaneously, so even superman could not track how the electron moves (at least according to quantum mechanics). Assume you measure the position of the electron exactly. Then you are left with total uncertainty for the momentum of the electron. Now you say: ok, I measure it directly afterwards. The point is, if you determine afterwards momentum exactly, you are left with total uncertainty for the position after your momentum-measurement.
Maybe the "Q" from Star Trek know about a more "microscopic" theory than quantum mechanics, which allows them to track electrons. But all theories we know so far do not allow it.
Speaking of superman: there's a nice movie on the double slit experiment (although a bit silly), where you can see that even superman has to obey the laws of physics ;) Unfortunately it is in german:
Thanks in advance!
Please read Post #5 in the FAQ thread in the General Physics forum.
Zz.
Thanks:) nice video:) like it..quantum world is so interesting and so difficult to understand it with my limited classical experiences. Yeah, thanks again, and going to sleep now, and see u around. Good night.
Sunset said:
Hi luxiaolei!
I wouldn't call it violation, then. But maybe that's a matter of taste.
And more unfortunately the electrons glint in the light as they whizz past so you can see them and yet they still make an interference pattern. It's a shame the fancy animators didn't get more advice from physicists.
  • · Replies 20 ·
  • · Replies 33 ·
