When does the LHC find out if higgs boson exist?
The discussion centers around the timeline and conditions under which the Large Hadron Collider (LHC) might confirm the existence of the Higgs boson. Participants explore the complexities of data analysis, statistical significance, and the challenges faced in distinguishing signal from background in experimental physics.
  • Some participants suggest that the LHC will need convincing experimental data to claim a discovery of the Higgs boson.
  • There is a discussion about whether any evidence for the Higgs boson has already been found, with some indicating that it is possible but not quantifiable at this stage.
  • One participant explains that the discovery claim relies on statistical analysis of signal versus background events, which can take a significant amount of time to gather sufficient data.
  • Another participant notes that the mass of the Higgs boson will affect how long it takes to gather the necessary statistics, with a lighter Higgs being more challenging to detect.
  • Concerns are raised about the timeline for official announcements, with references to historical precedents in particle physics where discoveries were not announced until thorough verification was completed.
  • There is speculation about the possibility of finding other particles before confirming the Higgs boson, though the relevance of such findings is debated.
  • Some participants reflect on the cautious nature of scientific announcements, emphasizing the importance of thorough validation before public claims are made.
Participants express a range of views on the timeline for discovering the Higgs boson, with no consensus on when or if it will be confirmed. Some believe it could take a couple of years, while others suggest it may take longer depending on various factors.
The discussion highlights the complexities involved in particle detection and the statistical methods required to distinguish between signal and background events. There are also references to historical timelines for previous discoveries, indicating that the process may be lengthy and cautious.
This discussion may be of interest to those following developments in particle physics, particularly regarding the Higgs boson and the operations of the LHC. It may also appeal to individuals curious about the scientific process of discovery and verification in high-energy physics.
clm321
when is the LHC find out if higgs boson excist?
When they get convincing experimental data.
Zz.
ya but they have collided particles already shouldn't they know now? have they found any rvidence at all from the LHC?
In fundamental physics, we claim discovery when we have checked our results beyond doubt on statistical fluctuations. When you search for the Higgs boson, you make spectra with a certain number of background events (continuous background) and a certain number of signal events (peak above the background). That means the LHC analysis must gather more events in the peak than what is expected from solely the background. Unfortunately, the backgrounds for Higgs boson are rather large and tricky to keep under control. It will therefore take quite some data (and time) before a discovery can be claimed : of the order of months, more likely a couple of years, of good data.
yes that makes sense, but what I am asking is if they have found ANY data at all to there possible existence.
It's possible that they already have, but nobody can tell you a likelihood right now. We will be able to compute the likelihood that they have already produced a Higgs once we know if the Higgs boson exist, and if so what its mass is. What you must realize is that even then (once we would supposedly know the Higgs boson and its mas), we will not be able to tell, event by event, whether the Higgs boson was produced. By definition, signal and background are impossible to distinguish on an event by event basis. Same initial state, same final state, only a large sample with statistical analysis can help you distinguish signal from background.
ok so do you have any approximite idea when they should know?
If the Higgs boson exists, how long they will need to gather statistics depends on its mass . It seems the Higgs boson is more likely to be light (from Tevatron) so it's the difficult case, and you will have to wait at least a couple of years.
dang iv been rather excited to find out but patience is vertue
I've been waiting for over thirty years to find out if the Higgs exists. I can wait another year or two. :smile:
it's going to be quite a while before the LHC experiments formally announce that they have seen the Higgs. Even if they find it relatively quickly (say, in the first year or two), this is such an important discovery, that the scientists are going to want to double-triple-quadruple-check that the analysis is right. Then, they'll want to check it again!
The top quark was "discovered" in the early 1990's, but the actual announcement of its discovery was not until 1995. We're just going to have to wait for it. Better safe and sure, than being the laughing stock of the scientific community when they have to withdrawal the paper due to an error...
The most likely three-sigma discovery target, assuming it's there at all and assuming no further engineering delays, is (as far as I know) two to three years from the time the collider is launched at full luminosity. There is a possibility that we'll find something other than Higgs before than and it'll make the search for Higgs irrelevant.
Is that for full luminosity at the full 14 TeV center-of-mass energy? Since they've decided to run for the first 2 years at only 7 TeV, my impression is that even after the end of those 2 years they still may only have data more or less comparable to the Tevatron (with respect to detecting a standard model Higgs). Then they're going to shut down to replace all the interconnects. It seems like you probably shouldn't start holding your breath just yet. It may take a number of years (possibly 5 or more, especially if it's in lower part of the mass range).
There's certainly the possibility of finding something else first, but I'm not sure what they could find that would make the Higgs search irrelevant.
I'm not affiliated with any of these experiments, though, so my impression may not be correct.
That's not my recollection - and I was there. (Along with 900 other people, of course)
Tevatron "Run I" began in 1992. The 1992-1993 run led to the 1994 CDF paper http://arxiv.org/PS_cache/hep-ex/pdf/9405/9405005v1.pdf" . CDF was in a difficult position - there were not enough top candidate events for a discovery, but there were too many for an improved limit compared to their last paper - which had only 20% of the data. Hence a paper that didn't really answer the question "do you see it or not"?
In 1995, midway through the second half of Run I (50 pb-1 for D0 and 67 pb-1 for CDF), both experiments wrote "Observation" papers.
I was only in High School back then, so I have to bow to your hands-on knowledge! :wink:
I was only trying to make the point that even though there was evidence earlier than 1995, CDF and D0 were careful not to publish their discovery papers until they were prepared to stand by the result, which is always good practice for science! I think of the famous scene where everyone just started clapping in the auditorium after running out of ideas for why the result might be wrong.
The top quark had been "discovered" previously in the 1980s at 40 GeV, and then at 120 GeV, so there was plenty of reason to want to be careful! All I meant to say was that even when the Higgs is "discovered," which may or may not happen early in the Run, I think ATLAS and CMS will be cautious before announcing their results publicly. At least, I hope they will be.
quarkballs (glueballs), teknimesòns, leptoquarks?
What do you call quarkballs ? You mean exotic mesons ? I do not think the LHC is a well-suited place to search for QCD exotics.
Even if the Higgs is found once, it should take about two years until they officially anounce it.
