Rectifier Circuit, graph (output wave)
The discussion centers on the output waveform of a full rectifier circuit, specifically questioning why the circuit is active only when the input voltage reaches 4 volts. Participants clarify that the threshold voltage is not simply the sum of the diode's forward voltages, as only two diodes conduct at any given time during the waveform peaks. The confusion arises from interpreting the voltage levels and the representation of the output waveform, which should reflect the correct voltage levels of +/-2V rather than +4V.
  • Understanding of full-wave rectifier circuits
  • Knowledge of diode forward voltage characteristics
  • Familiarity with waveform analysis
  • Basic electrical engineering principles
  • Study the operation of full-wave rectifier circuits in detail
  • Learn about diode characteristics and their impact on circuit performance
  • Explore waveform sketching techniques for rectified outputs
  • Investigate the effects of load resistance on rectifier output voltage
Electrical engineering students, circuit designers, and anyone interested in understanding rectifier circuits and waveform analysis.
calvert11
Sketch the output waveform:
http://img7.imageshack.us/img7/3774/recgraph.jpg
(The coloured lines I added myself)
Nothing which applies, I think.
The answer has already been provided. I just have a concept question.
The full rectifier circuit is active only where the input voltage is 4 or greater (marked in blue). But why 4?
Is it simply the sum of the 4 diode's threshold voltages (marked in red), that is, 1+1+1+1=4?
But only 2 diodes are active at a time (at each peak or valley of the input wave), right? So, why isn't it 1+1=2 instead?
Or am I on the wrong track entirely?
I believe it should be 2V in the + direction and 2V in the - direction. Is there a chance that is where they got the 4? It still shoule be shown as +/-2V on the triangle wave, though, not +4V. Was that picture part of the solution, or an interpretation of a written answer?
