Thermodynamics - Change in Density due to Change in Height
The problem involves a column of water containing fine metal particles in thermal equilibrium, focusing on how the density of these particles changes with height. The context is rooted in thermodynamics and fluid mechanics.
  • Participants discuss the relationship between particle density and height, with one participant attempting calculations based on particle volume and mass. Another participant questions the forces acting on the particles to understand their behavior in the fluid.
The discussion includes attempts to calculate the particle density at a higher position, with one participant providing a detailed calculation that leads to a specific numerical result. However, there is no explicit consensus on the correctness of the approach or the final answer.
Participants are navigating assumptions about the behavior of particles in a fluid and the effects of gravitational forces, as well as the implications of thermal equilibrium on particle distribution.
Hart
A column of water contains fine metal particles of radius 20nm, which are in thermal
equilibrium at 25°C.
The density of the metal is [tex]2\times10^{4} kg m^{-3}[/tex].
If there are 1000 particles per unit volume at given height, what will the particle density per unit volume be at a position of 1 mm higher?
Stated within the question / solution attempt.
For each particle:
Radius = [tex]20\times10^{-9}m[/tex]
Hence Volume = [tex]\frac{4}{3} \pi (20\times10^{-9}m^{3} = 3.351\times^{-23}m^{3}[/tex]
Therefore since density is mass divided by volume, [tex]\rho = \frac{m}{V}[/tex]:
[tex]m_{total} = \rho m = (2\times10^{4} kg m^{-3})(3.351\times^{-23}m^{3}) = 6.702\times^{-19}kg[/tex] which is the total contained mass.
It is given that at any height there are 1000 particles, therefore:
[tex]m_{particle} = \frac{6.702\times^{-19}kg }{1000} = 6.702\times^{-22} kg[/tex]
I thought this would probably help somehow, not sure how anymore though.
Ask yourself, 'What's keeping the metal particles from falling to the bottom?'.
.. little more help? :blushing:
  1. Using known radius of a particle have found the volume of a particle.
  2. Using this value of volume, and the known pressure, have found the mass.
  3. Using this value of mass, and known values of g and h, have found the energy:
    [tex]E = mgh = (m)(9.81)(1\times10^{-3}) = 6.6\times10^{-21}[/tex]
  4. Using Boltzmann constant [tex]k_{B}[/tex] and T (converted into Kelvin), can now put all these values into the Stefan-Boltzmann equation:
    [tex]n = n_{0}exp\left(\frac{-E}{k_{B}T}\right) = (1000)(0.202) = 202[/tex]
  5. Therefore at position of 1mm higher, the particle density is: 202 particles per unit volume.
.. hopefully correct :smile:
