How to Calculate Mechanical Energy Lost During a Fall?
The discussion focuses on calculating the mechanical energy lost by a 6.0 kg concrete block dropped from a height of 55 meters. The gravitational potential energy (PE) at the release point is calculated using the formula PE = mgh, yielding 3230 J. The kinetic energy (KE) at impact is determined using KE = 1/2 mv², resulting in 2700 J. The mechanical energy lost during the fall is attributed to air friction, as the potential energy is converted into kinetic energy and some energy is dissipated as heat due to air resistance.
  • Understanding of gravitational potential energy (PE = mgh)
  • Knowledge of kinetic energy (KE = 1/2 mv²)
  • Familiarity with the concept of mechanical energy conservation
  • Basic principles of air resistance and friction
  • Study the conservation of mechanical energy in physics
  • Learn about the effects of air resistance on falling objects
  • Explore advanced calculations involving energy loss in real-world scenarios
  • Investigate the impact of mass and height on potential and kinetic energy
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy transformations during free fall.
zelda1850
a 6.0kg concrete block is dropped from the top of a tall building. the block has fallen a distance of 55 meters and has a speed of 30 meters per srcond when it hits the ground
1) at the instant the block was released what was the gravitational potenetial energy with respect to the ground?
2)calculate the kinetic energy of the block at the point of impact?
3) how much mechanical energy was lost by the block as it fell?
4) explain what happened to the mechanical energy that was lost by the block?
1) pe = mgh so 6kg x 9.81m/s2 x 55m = 323 j
2) ke = 1/2mv2 so 6kg x 30m/s2 divided by 2 = 2700 j
3) how can i find the energy lost do i subtract the kinectic with the potential
4) how can i explain how the energy was lost was it because it was falling?
is their a formula to finding mechanical energy lost?
First off, for part 1.) you lost a zero. The answer is 3.23 KJ = 3230 J. You should have spotted this due to the unrealistic nature of an object gaining more kinetic energy than was available in potential energy. Second, for part 3, you have it reversed. The total energy available at t = 0 is the potential energy. By the time it hits the ground, all potential energy is gone. Some of it is kinetic and some of it is that sought after mechanical loss. I'd explain the losses with friction of the air -- also known as wind resistance.
so the mechanical energy was lost due to friction of the air?
  • · Replies 22 ·
  • · Replies 22 ·
