Thread Closed
Is metallic hydrogen superconductive at 273k
Share Thread Thread Tools
Feb22-10, 11:55 PM   #1
and if so is it the highest temperature superconductor known?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
>> New insights into how materials transfer heat could lead to improved electronics
Feb23-10, 05:53 AM   #2
Recognitions:
Gold Membership Gold Member
No one has -as far as I know- ever even demonstrated that metallic hydrogen is a superconductor (all known phases are insulating). It is most definitely not a superconductor at 273K
(which is a bit of a "silly" temperature anyway, it happens to be equal to 0 degrees Celsius which is also the freezing temperature of water; it would if nothing else be a HUGE coincidence if metallic H had a Tc of that temperature).
Feb23-10, 08:35 AM   #3
Quote by Wikipedia
Superconductivity:
In 1968, Ashcroft put forward that metallic hydrogen may be a superconductor, up to room temperature (~290 K), far higher than any other known candidate material. This stems from its extremely high speed of sound and the expected strong coupling between the conduction electrons and the lattice vibrations.
...The team had sought simply to measure the less extreme electrical conductivity changes which were expected to occur. The researchers used a 1960s-era light gas gun, originally employed in guided missile studies, to shoot an impactor plate into a sealed container containing a half-millimeter thick sample of liquid hydrogen. The liquid hydrogen was in contact with wires leading to a device measuring electrical resistance. The scientists found that, as pressure rose to 1.4E+6 atm (142 GPa), the electronic energy band gap, a measure of electrical resistance, fell to almost zero.
Reference:
metallic hydrogen superconductivity - Wikipedia
Feb23-10, 09:34 AM   #4
Recognitions:
Yes, metallic hydrogen has been predicted to be superconducting at very high temperatures. But no one has actually shown that this prediction is correct.
Also, the pressure needed to keep the hydrogen metallic at 290K would be truly enormous.
Thread Closed
Thread Tools
Similar Threads for: Is metallic hydrogen superconductive at 273k
Thread Forum Replies
metallic hydrogen Atomic, Solid State, Comp. Physics 0
Is hydrogen non-metallic? Biology, Chemistry & Other Homework 3
metallic hydrogen Chemistry 12
Muon-Catalyzed Fusion of Metallic Hydrogen High Energy, Nuclear, Particle Physics 3
Metallic Hydrogen... Atomic, Solid State, Comp. Physics 8
