Charge on a glass bead derived from potential difference between 2 points
The discussion focuses on calculating the charge of a positively charged glass bead with a diameter of 2.0 mm, given a potential difference of 500V between two points at distances of 3.0 mm and 5.0 mm from the bead's center. The correct formula used is V = Kq/r, leading to the conclusion that the charge on the bead is approximately 2.23 x 10^-10 C. A common misunderstanding was clarified: the distances provided refer to the edge of the bead, not the center.
  • Understanding of electrostatics and electric potential
  • Familiarity with Coulomb's law and the constant K (Coulomb's constant)
  • Knowledge of basic algebra for solving equations
  • Concept of electric field and potential difference
  • Study the derivation and applications of Coulomb's law
  • Learn about electric potential and its relationship with charge
  • Explore the concept of electric field strength and its calculations
  • Investigate common mistakes in electrostatic problems and how to avoid them
Students studying electrostatics, physics educators, and anyone looking to deepen their understanding of electric potential and charge calculations.
samdunhamss
A 2.0 mm diameter glass bead is positively charged. The potential difference between a point 2.0 mm from the bead and a point 4.0 mm from the bead is 500V. What is the charge on the bead?
Actual Answer
4.2*10^-10
I am unable to understand or even get near this answer. Any help is greatly appreciated.
V = Kq/r
V = kq[1/r -1/r']
500 V = 9x10^9 (q) [1/.004-1/.006]
500/((9x10^9)(1/.004-1.006)) = q
q= 2.23x10^-10
'Just worked it out. It's kind of silly. When the problem says "a point x mm from the bead", it does not mean from the center of the bead. It means from the edge of the bead. So the two points in question are actually 3 mm and 5 mm from the bead's center.
[Edit] By the way, in your original attempt you were using the bead's diameter instead of its radius, to get the distance to the center.
Thank you, your help is appreciated.
  • · Replies 30 ·
  • · Replies 22 ·
