What is the reaction order of SN1
  • Thread starter Thread starter shredder666
    Reaction
The discussion centers on the reaction order of the SN1 mechanism, specifically the rate-determining step. The consensus is that the SN1 reaction is first order, as it involves only the substrate in the rate expression, represented as rate=k[substrate]^1. The argument against zeroth order is based on the fact that the leaving group does not leave spontaneously in all conditions, and the concentration of the substrate significantly influences the reaction rate. The role of the solvent is acknowledged, but it does not alter the fundamental order of the reaction.
  • Understanding of SN1 reaction mechanisms
  • Familiarity with reaction order concepts
  • Knowledge of rate-determining steps in chemical reactions
  • Basic principles of solvent effects on reaction kinetics
  • Study the kinetics of SN1 reactions in various solvents
  • Explore the concept of rate-determining steps in multi-step reactions
  • Investigate the effects of dielectric constants on reaction rates
  • Learn about the differences between first order and zeroth order reactions
Chemistry students, organic chemists, and anyone studying reaction kinetics and mechanisms will benefit from this discussion.
shredder666
Sorry the title is bit misleading, I'm actually talking about the rate determining step of SN1 mechanisms. I thought it was first order, but my teacher disagrees.
he argues that it is zeroth order because in the appropriate solvent, the leaving group leaves spontaneously regardless of its concentration, thus the rate expression
rate=k[substrate]^0
my argument is that first, it is unimolecular substitution, thus the name SN1 (I'm only talking about the rate determining step, not the whole reaction).
Second only the substrate was involved in the reaction itself. The solvent just modifies the K value. Thus the rate expression
rate=k[substrate]^1
I do realize that a lot of texts (that I know of) tends towards my argument, but please ignore it for now, for most mechanisms are only proposed.
thank u
Chemistry news on Phys.org
As a your teacher says, that the leaving group will leave spontaneously in the appropriate solvent. So that isn't good enough to generalisation that all SN1 reactions are of zeroth order.
But let's assume that the Formation of the carbocation,i.e, the rate-determining step, is spontaneous. Then it will no longer remain the slowest step. It will, in fact, proceed faster than the second step of the reaction. And automatically the second step will become the slowest step and determine the rate. So, you end up with a second order reaction, anyway. A total contradiction.
Further, The rate of a reaction depends on all the steps in the reaction. If you have a step which is prominently slower than all others, it becomes the rate determining step, because here, the rates of the other steps do not greatly affect the rate of the overall reaction. If the rates of the steps involved are comparable, you will have a complicated rate law equation. So even by this argument you may get a complicated rate law, but zero order isn't probable.
shredder666 said:
...he argues that it is zeroth order because in the appropriate solvent, the leaving group leaves spontaneously regardless of its concentration, thus the rate expression...
If that is what your teacher said, then teacher is wrong. Spontaneity is not the correct term to use in a reaction order or rate of reaction discussion. How the concentration of the species that is ionizing affects the overall rate of the reaction is the only pertinent point to discuss.
It is well known that solvent effects affect the rate of reaction but not the reaction order. A high dielectric solvent might lower the energy barrier leading to the reactive intermediate and thus increase the rate, but how the concentration of that species affects the overall rate remains unchanged... first order for SN1.
  • · Replies 131 ·
11K
12K
  • · Replies 19 ·
11K
