If a is an element of R can you assume -a is an element of R?
  • Thread starter Thread starter The_Iceflash
    Element
The discussion revolves around the properties of real numbers, specifically whether the negation of a real number is also a real number. The context is related to abstract algebra and the foundational properties of real numbers as they pertain to proofs in this area.
  • Participants explore the implications of assuming that if a is a real number, then -a must also be a real number. Some suggest that scalar multiplication in vector spaces maintains membership in the same space, while others reference the closure properties of real numbers in the context of abstract algebra.
The discussion is active, with various participants providing insights into the assumptions that can be made regarding real numbers in proofs. There is recognition of the need to rely on established properties of real numbers without needing to prove them from scratch in the context of abstract algebra.
Participants note that the discussion is influenced by the requirements of their coursework, particularly in abstract algebra, where certain axioms about real numbers are assumed to be known.
The_Iceflash
Simply like the title says, "If a is an element of R can you assume -a is an element of R?"
R={All Real Numbers}
N/A
I concluded that if a is a real number so must -a. Can that be assumed in a proof? Should a simple "If a [tex]\epsilon[/tex] R, then -a [tex]\epsilon[/tex] R" be sufficient?
EDIT: It has to do with a proof on groups in Abstract Algebra.
I may be wrong, but if we are talking about Vector Spaces, And if we know that 'a' is in the vector space R, then any scalar multiplication keeps it in the same vector space.
if a is in R,
(-1)*a is also in R
If this is an abstract algebra question, use the fact R is an ordered field, and R is closed under addition and multiplication.
Yes it is for Abstract Algebra. I apologize. I should have noted that.
the existence of the identity guarantees the inverse of a.I mean what are the assumptions you are allowed to make?
I find it funny that things like " a+(-a)=0" , which are so intuitively obvious, are so conceptually difficult to prove without making assumptions.
If this is for abstract algebra, then "R is a field (or ring)" is all that's needed. It's one of the axioms.
Your question isn't so much about abstract algebra but rather what you can assume you know about the real numbers in writing down proofs. It does depend on the context. If a problem asks you to prove that (R,+) is an abelian group, for example, I don't think it's necessary to explicitly prove that x+y=y+x, but you can simply state that it is based on your previous knowledge of how the real numbers work. For your class, you need to assume certain properties about the real numbers, otherwise you're going to be spending all your time reconstructing the set of real numbers and deriving its properties, which isn't really the point of the course.
  • · Replies 24 ·
