| Thread Closed |
Thought Experiment |
Share Thread | Thread Tools |
| Feb25-10, 05:22 AM | #1 |
Thought Experiment
There is an empty container on some weighing scales.
It is filled with electrons & positrons, the lid is closed and a reading of the weight is taken. Now they go boom and are turned into gamma rays... Lets say the box does not let the rays escape, instead are reflected back inside the container. What happens to the scales, do they read less than before, more than before, or the same? (Sorry if this is the wrong board) |
| Feb25-10, 06:05 AM | #2 |
Hi Raekwon!
![]() Mass is energy, energy is mass … if nothing escapes from the container, and if no energy was supplied to cause the "boom", then the mass, and therefore the weight, will be exactly the same. |
| Feb25-10, 06:08 AM | #3 |
Exactly my thoughts, but someone said because of E=mc2 that it would weigh less, which got me doubting myself, I guess they must have thought that light is massless and disregarded the conservation of mass. Thanks.
| Feb25-10, 10:51 AM | #4 |
Thought ExperimentYes, energy is mass, so stretching something, or compressing it, away from its equilibrium state, will increase its mass. |
| Feb25-10, 12:02 PM | #5 |
Positrons, like electrons, have mass. But do positrons have the same "weight" as electrons? It is not obvious that the gravitational force is the same for positrons and electrons. Does matter gravitationally attract or repel antimatter? There are known subtle differences between particles and antiparticles, notably CP asymmetry, so why not gravitational force also? There are proposals for testing the gravitational force on anti-hydrogen in the low energy antiproton ring at CERN. See the proposed AEGIS experiment listed in
http://en.wikipedia.org/wiki/Antiproton_Decelerator See discussion at http://en.wikipedia.org/wiki/Gravita..._of_antimatter If antimatter were known to be attracted to matter, then the AEGIS experiment would be unnecessary. Bob S |
| Feb25-10, 12:24 PM | #6 |
| Feb25-10, 12:25 PM | #7 |
This is what never understood, if energy is mass, what is the photon?
Why is the photon massless? |
| Feb25-10, 12:29 PM | #8 |
The photon has zero rest-mass (it needs it so that it can travel at the speed of light). |
| Feb25-10, 12:56 PM | #9 |
If it has mass does it have weight? Sorry for the dumb questions but google doesn't help, I found this and i'm more confused: http://www2.corepower.com:8080/~relfaq/light_mass.html |
| Feb25-10, 01:45 PM | #10 |
Its mass equals its energy.
If it's contained inside a box (eg a fibre optic cable), then the box will have more mass, and will weigh more. |
| Feb25-10, 10:21 PM | #11 |
The actual answer to the author's question is that the box would weigh a bit less after the recombination. How much less? Answer: Box Weight minus 1/4-total positron/electron pair weight.
The positron/electron pairs, being massive, will have weight. Gamma rays, being massless yet possessing momentum will have no weight. Thus the momentum from the confined gamma rays will act on all sides of the box as to provide a downwards thrust equal to 1/4 the weight of the original positron/electron pairs. |
| Feb25-10, 11:09 PM | #12 |
Mentor
Glen, that turns out not to be the case. The box weighs the same. Gamma rays do have weight, although the simplest way to show this is simply to show E2 - p2 is the same before and after.
| Feb26-10, 04:56 AM | #13 |
What if we have:
p2 = E2/c2 - m2c2 (E2 = p2c2 +m2c4) If we apply energy to it instead of mass, we get: p = E/c Therefore: p2 = p2 - m2c2 Therefore: m2c2 = 0 We know c is more than 0, so m is 0 So, E = mc2/sqrt(1 - v2/c2) will be the only way a particle can have a non-zero mass. |
| Feb26-10, 06:34 AM | #14 |
Mentor
Hi Raekwon,
The easiest way to keep this clear in your mind is to distinguish between the mass of an individual particle and the mass of a system. Energy and momentum can be placed together into one single geometrical object, called a four-vector. If you do this, then mass is simply the length (Minkowski norm: s² = c²t²-x²-y²-z²) of the energy-momentum four-vector. This is important because, in any interaction, the four-momentum is conserved which, in turn, means that mass is conserved. Now, just like the length of the sum of two vectors is, in general, different than the sum of the lengths of the two vectors (triangle inequality), similarly with four-vectors. So the mass of a system (the length of the sum of the particle's four-momenta) is in general different than the sum of the masses of the individual particles (the sum of the lengths of the particle's four-momenta). So, one photon is massless, but a system composed of two or more photons may have mass. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thought Experiment
| Thought Experiment | General Physics | 9 | ||
| Thought experiment (SR) | Special & General Relativity | 3 | ||
| One last thought experiment | General Physics | 9 | ||
| Thought Experiment | General Physics | 20 | ||
| A Thought Experiment | General Physics | 125 | ||
