| Thread Closed |
De Moivre's Theorem : z^3 |
Share Thread | Thread Tools |
| Feb26-10, 04:17 PM | #1 |
Hello
![]() I'm really stuck on this question, and was hoping someone could help me. 1. The problem statement, all variables and given/known data Find all complex numbers, z, that satisfy [tex]z^3 = \sqrt{3} - i[/tex] 2. Relevant equations [tex]z^n = r^n cis (n\theta)[/tex] [tex]r = \sqrt{a^2 + b^2}[/tex] [tex]\theta = tan^{-1}(\frac{b}{a})[/tex] Rotate anticlockwise by [tex]\frac{2\pi}{n}[/tex] radians 3. The attempt at a solution [tex]z^3 = \sqrt{3} - i[/tex] [tex]r = \sqrt{(\sqrt3)^2 + (-1)^2} = 2[/tex] [tex]\theta = tan^{-1}(\frac{-1}{\sqrt3}) = -\frac{\pi}{6}[/tex] [tex]z^3 = 2cis(-\frac{\pi}{6})[/tex] This is where I go wonky. ![]() [tex]n = \frac{1}{3}[/tex] [tex](z^3)^{\frac{1}{3}} = 2^{\frac{1}{3}}cis(\frac{1}{3}.-\frac{\pi}{6})[/tex] [tex]z = \sqrt[3]{2}cis(-\frac{\pi}{18})[/tex] Now, from what I've seen in the lectures, I'm supposed to add [tex]\frac{2\pi}{\frac{1}{3}}[/tex] radians, then [tex]\frac{4\pi}{\frac{1}{3}}[/tex] radians, then [tex]\frac{6\pi}{\frac{1}{3}}[/tex] to get [tex]2\pi[/tex], and thus complete one revolution (360 degrees). I've seen an Argand Diagram for this question divided into sections of 120 degrees, but I'm so confused. Could anyone help me please? I'd very much appreciate it. Thanks.
| Feb26-10, 07:40 PM | #2 |
Hi Matty
Ok, you have z3 = 2 cis (-π / 6), then using De Moivre's Theorem : z3 = 2 cis (-π / 6) r3ei3θ = 2e-i(π / 6) Comparing coefficient : 1) r3=2 2) ei3θ = e-i(π / 6) 3θ = -(π / 6) ---> this is where you add 2π, 4π, ...or add 2kπ, where k is integer so it will be : 3θ + 2kπ = -(π / 6) ---> You can also add 2kπ on RHS Then find θ using several value of k |
| Feb26-10, 07:44 PM | #3 |
Mentor
It's easier to work with an angle with positive measure, namely 11pi/6. You want values of z such that their 3rd powers are 2cis(11pi/6). If you have a complex number in polar coordinates, it's easy to calculate powers of that number by raising the modulus of the number to that power, and multiplying the angle (arg) by that power.
For example 1 + i = sqrt(2)cis pi/4, so (1 + i)2 = (sqrt(2))2cis pi2 = 2i. In your problem, can you work backwards and find a complex number whose cube is sqrt(3) - i? All three of the numbers are spread equally around the circle 120 deg. apart |
| Feb27-10, 08:51 AM | #4 |
Thank you so much for the replies.
![]() I think I may have worked it out now, but I'm still a bit confused. [tex]z^3 = 2cis(-\frac{\pi}{6})[/tex] [tex]z^n = r^ne^{in\theta}[/tex] [tex]z^3 = r^3e^{i3\theta} = 2e^{i(-\frac{\pi}{6})}[/tex] [tex]3\theta = -\frac{\pi}{6} = (-\frac{\pi}{6}) + 2k\pi[/tex] [tex]\theta = \frac{(-\frac{\pi}{6}) + 2k\pi}{3} = -\frac{\pi}{18} + \frac{2k\pi}{3}[/tex] [tex]z = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{2k\pi}{3})[/tex] [tex]OR = (\sqrt[3]{2})cis(-\frac{\pi}{18})[/tex] [tex]OR = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{2\pi}{3})[/tex] [tex]OR = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{4\pi}{3})[/tex] Should they be written like this instead, seeing as I've used the exponential form earlier: [tex]z = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{2k\pi}{3})}[/tex] [tex]OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18})}[/tex] [tex]OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{2\pi}{3})}[/tex] [tex]OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{4\pi}{3})}[/tex] |
| Feb28-10, 09:11 PM | #5 |
Mentor
Well, yes, but that doesn't tell your what the three cube roots are.
| Feb28-10, 11:47 PM | #6 |
I W-A'd it... and only got 1 answer.
| Mar1-10, 07:03 AM | #7 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: De Moivre's Theorem : z^3
| De Moivre's theorem | Precalculus Mathematics Homework | 4 | ||
| [SOLVED] Starting to prove by De Moivre's Theorem | Calculus & Beyond Homework | 13 | ||
| De Moivre's Theorem | Calculus & Beyond Homework | 2 | ||
| prove using de moivre's theorem of I=cos^2n theta | Calculus & Beyond Homework | 3 | ||
| Great Fun: Complex Proof using de Moivre's Theorem | Calculus & Beyond Homework | 4 | ||
