Question envolves the centre-of-mass and momentum.
  • Thread starter Thread starter Philippe007
    Momentum
The problem involves an elastic collision between an electron and a hydrogen atom at rest, focusing on the fraction of the electron's initial kinetic energy transferred to the atom. The mass of the hydrogen atom is given as 1840 times that of the electron.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conservation of momentum and kinetic energy, attempting to derive relationships between the velocities of the electron and hydrogen atom. There are questions about how to handle the three unknown velocities with only two equations available.
Participants are actively exploring the relationships between initial and final kinetic energies, with some guidance provided on expressing one variable in terms of another. There is recognition of the challenge posed by having more unknowns than equations, and the discussion is focused on deriving a ratio of kinetic energies.
There is an ongoing debate about the correct approach to express the kinetic energies in terms of the available variables, with some confusion regarding the application of equations and the nature of the collision.
Philippe007
An electron collides elastically with a hydrogen atom that is initially at rest. Assume all the motion occurs along a straight line. What fraction of the electron's initial kinetic energy is transferred to the atom? (Take the mass of the hydrogen atom to be 1840 times the mass of an electron.)
KE = (1/2)mv^2
uapp = vsep
p = mv
I used the formulas above, and came up with 3 equations:
p-cons
u1x = v1x + 1840v2x
u1x = v2x - v1x
KE
u1x^2 = v1x^2 + 1840v2x^2
But i keep trying and can't use them to find anyone velocity.
Philippe007 said:
p-cons
u1x = v1x + 1840v2x
u1x = v2x - v1x
Just combine these to get V1 in terms of U1. That's all you need to compare initial and final KE of the electron.
(Note that the second of these two equations comes from combining conservation of momentum with conservation of energy.)
You can't because you have three velocities and really only two equations. The equation u1x = v2x - v1x was derived by combining the conservation of momentum and conservation of kinetic energy equations.
In any case, it doesn't matter because the problem is asking for the fraction of the electron's initial kinetic energy transferred to the atom. If you write that down mathematically, you'll see what you need is a ratio of two of the velocities, which is a quantity you can solve for.
I have tried combining the two equations, but that only gives me a new equation with two unknown velocities, and I need all three velocities to find the inital and final KE.
How would I use an equation with 2 unknown variables to compare the initial and final KE??
Help??
As I said earlier, just solve for V1 in terms of U1. Then you can compare the ratio of the final and initial KE of the electron. (You don't need all three velocities.)
So your saying that when you add the equaitons and get:
V1i = 1841v2f
How can this be used to compare the two KE?
since KEi = (1/2)mv^2
KEi = (1/2)(1)(1841v2f)^2
It doesn't give an actual number, and again there ends up with two variables
and then KEf would be:
KEf = (1/2)(1)(v1f)^2 + (1/2)(1840)(v2f)^2
neither of these can really be compared to give a percentage??
I didn't say anything about adding the equations. Solve for V1 in terms of U1. (Hint: Eliminate V2.)
You did say to combine the equations. But, when you do solve for u1, there are still 2 variables, and you can't find the KEf or KEi without at least one of these, and therefore can't compare the two.
You have two equations and three unknowns. Eliminate V2. Then express V1 in terms of U1.
Do it.
Ok:
u1x = v1x + 1840v2x
u1x = v2x - v1x
so...
v2x= u1x + v1x
and then...
u1x = v1x + 1840(u1x + v1x)
u1x = v1x + 1840u1x + 1840v1x
-1839u1x = 1841v1x
u1x = -1841v1x/1839
there.
What is this even showing me. I have still have 2 unknowns?
Philippe007 said:
u1x = -1841v1x/1839
there.
Good. (I meant to say, Express V1 in terms of U1.)
Now:
What's the initial KE of the electron? (This will be in terms of U1, of course.)
What's the final KE of the electron? (Express it in terms of U1.)
Compare! (Find the ratio: KEf/KEi)
So, I did what you said, and its starting to look like an answer, thanks for that.
But now I have:
u1x = (u1x)^2 ((1839/1841)^2 + (1840)(2/1840)^2)
with the left side being inital and the right side being the final KE's
I was wondering though, how would I convert that into a percentage?
But now I have:
That equation couldn't possibly be correct. You have a velocity on the LHS, not a KE, and the RHS side is a velocity squared, also not a KE.
Write down KEi in terms of u1x and KEf in terms of v1x. Divide one by the other. You'll end up with a ratio which you can evaluate given your earlier result.
But now I have:
Not sure what you did here.
KEi = 1/2m(U1)^2
KEf = 1/2m(V1)^2
Express V1 in terms of U1, then rewrite KEf in terms of U1.
KEi = 1/2m(U1)^2
KEf = 1/2m(V1)^2
Oh i think its because i used KEf = 1/2m1(v1f)^2 + 1/2m2(v2f)^2
Wouldnt that be right?
No, that ratio would come out to be 1 because it's an elastic collision, i.e. total KE(initial)=total KE(final). Go back and see what the question was actually asking for.
No. Just compare the initial and final KE of the electron, not the total KE.
