Thread Closed
Minimum thrust of engines at lift-off
Share Thread Thread Tools
Feb28-10, 02:18 AM   #1
Hi there
Rocket has a total mass of 3.4 x 10^6 kg at lift-off. The first stage contains 2.0 x 10^6 kg of propellants which is consumed at a rate of 1.4 x 10^4 kg s
Find the minimum thrust of the engines at lift-off?
I would have thought that you needed one more variable to be able to solve this?
2. Relevant equations
3. The attempt at a solution
I used the mass flow x escape velocity and ended up with 15.7 x 10^6 N. It takes 142 sec for the first stage to finish its burn.
I just dont think that this is right - as the next part states that if this thrust is sustained - find the time over which the first stage operates and the acceleration of the vehicle at that time. (Neglect air friction - and suume whole flight is vertical.
Help needed please. Cheers
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar1-10, 06:43 PM   #2
Any thoughts?
Cheers
Sep15-10, 12:29 PM   #3
Wouldn't the minimum thrust just be m*g? In order to get the rocket moving, you would need at least 3.3*10^7 N of force.
Thread Closed
Thread Tools
Similar Threads for: Minimum thrust of engines at lift-off
Thread Forum Replies
How would you determine the Lift(thrust) force of a Helicopter in hover Mechanical Engineering 20
small engines vs. big engines? General Engineering 75
Thrust,drag and lift on airplane Question Advanced Physics Homework 2
Minimum volume of LQG corresponds to a minimum energy? Beyond the Standard Model 3
Jet Thrust Mechanical Engineering 5
