| Thread Closed |
wave function problem |
Share Thread | Thread Tools |
| Mar1-10, 12:57 PM | #1 |
The function [latex] \Psi(r) = A(2-{Zr\over a})e^-{Zr\over 2a} [/latex] gives the form of the quantum mechanical wavefunction representing the electron in a hydrogen-like atom of atomic number Z when the electron is in its first allowed spherically symmetric excited state. Here r is the usual spherical polar coordinate, but, because of the spherical symmetry, the coordinates θ and φ do not appear explicitly in Ψ. Determine the value that A (assumed real) must have if the wavefunction is to be correctly normalised, i.e. the volume integral of |Ψ|^2 over all space is equal to unity. 3. The attempt at a solution [latex] {\int \int \int}_R |\Psi|^2 dV = 1[/latex] [latex] \int _0^{\infty }\int _0^{2\pi }\int _0^{\pi }A^2e^{-\frac{Zr}{a}} \left(2-\frac{Zr}{a}\right)^2d\phi d\theta dr = 1[/latex] Which implies [latex] \int _0^{\infty }A^2e^{-\frac{\text{Zr}}{a}} \left(2-\frac{\text{Zr}}{a}\right)^2dr = {1\over 2\pi^2}[/latex] This turns out to be [latex] \frac{2aA^2}{Z} = \frac{1}{2\pi^2} [/latex] [latex] A = \pm \frac{\sqrt{\frac{z}{a}}}{2\pi} [/latex] This is wrong though? Is the problem the fact that Psi(r) isnt a function of theta or phi? |
| Mar1-10, 01:16 PM | #2 |
Recognitions:
Looks to me you forgot the r2 sin term from the differential volume element (note that the way you did it, the volume of a unit ball would come out as 2pi2). See http://en.wikipedia.org/wiki/Spheric...rdinate_system
| Thread Closed |
| Thread Tools | |
Similar Threads for: wave function problem
| Hydrogen Atom Radial Wave Function (limit problem) | Quantum Physics | 7 | ||
| Determine a function that calculates the nth weight factor of a wave function | Advanced Physics Homework | 0 | ||
| Nonsinusodial wave function problem | Introductory Physics Homework | 2 | ||
| Wave function proving problem | Introductory Physics Homework | 1 | ||
| Particle in a box... wave function problem | Advanced Physics Homework | 8 | ||
