| Thread Closed |
Sizing Secondary Systems |
Share Thread | Thread Tools |
| Aug5-04, 08:18 AM | #1 |
I would like to get some opinions on secondary circulator and piping design for heating system.
System Description: Two (2) boilers each one is 75% of building total heating load. Each with a secondary circulator pumping to a manifold into a primary loop. The return piping comes from a second manifold adjacent to to supply manifold. Primary loop with two (2) parallel circulators moving the heating water 100% of the heating load using a 20 deg F TD to the building and through the equipment. Okay, the boiler manufacturer suggests the formula: Gross Output BTUH/(Temp Rise x 500) = Secondary gpm Temp Rise = 230 deg F - Return Water Temp I know that the boiler can handle higher flows than will be obtained through this formula (with a 70 deg Temp Rise and a 515,000 btuh boiler I only get 14.7 gpm). So which is better, use less water at higher temperature, or use more water at lower, closer to system, temperature? Or is it best to figure a compromise and go with that? Say a 40 deg F or 50 deg F temperature rise in the boiler? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Sizing Secondary Systems
| Sizing of DC motors | Electrical Engineering | 4 | ||
| need simple help for compressor sizing | Mechanical Engineering | 0 | ||
| Shaft Key Sizing | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Pre-sizing | General Discussion | 23 | ||
| Sizing a mototr to the right torque | General Physics | 1 | ||
