Thread Closed
dc motor 2 direction switch
Share Thread Thread Tools
Mar1-10, 11:44 PM   #1
Hi experts,
is it possible to have a simple 2-directional switch using just 2 12v coil relays (having normally opened and closed contacts)? Is this equivalent to a h-bridge or must a h-bridge be used? The triggering is from a 555 to the relay coils.
I tested my circuit but it does not seem to switch polarity even though the relays switched! This resulted in only 1 directional spinning for the half cycle and then the in the other half cycle the motor halts which i suspect is due to shortcuiting.
But the circuit seemed to work at times bi-directionally. So, this is why i like to confirm if 2 relays can perform a h-bridge.
regards
Ramone
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Mar2-10, 01:09 PM   #2
You need a single DPDT (double pole double throw) relay or equivalent wired as a cross (X) switch. There are two types of DPDT relays; make before break, and break before make. You need the latter.
Bob S
Mar3-10, 06:30 AM   #3
Sorry Bob S and forummers,
I think my relay is of type Single Pole Double Throw, not DPDT. My appologies.
Here is how it looks like : http://www.flickr.com/photos/46348930@N03/?saved=1
There are 2 contact points for the switch (common) : one is the normally opened and the other is the normally closed.
I am using 2 spdt relays as my h-bridge controlled by a 555.
I wish to confirm that this is feasible as a h-bridge. Currently, my configuration is not working properly and only momentarily does it oscillate between 2 directions.
Thanks.
Thread Closed
Tags
h-bridge
Thread Tools
Similar Threads for: dc motor 2 direction switch
Thread Forum Replies
rotation direction of an ac induction motor Electrical Engineering 5
the mud flies off the tyre of a moving motor cycle in the direction: Classical Physics 7
[3 phase induction motor] direction of rotation Electrical Engineering 6
motor as switch (dc transformer) Electrical Engineering 14
