Concerning Elastic collisions and Kinetic energy
The problem involves an elastic collision between two balls, one with mass 2m moving at velocity Vo and another with mass m at rest. The task is to find the minimum kinetic energy of the system, while considering the conservation of kinetic energy during the collision.
  • The original poster expresses confusion regarding the expected outcome and the nature of kinetic energy conservation in elastic collisions. Some participants question the clarity of the problem statement and the correctness of the expected answer. Others discuss the temporary changes in kinetic energy during the collision and the role of potential energy in the context of deformation.
Participants are exploring different interpretations of the problem, particularly regarding the conservation of kinetic energy during the collision. There is no explicit consensus on the expected answer, but some productive insights about the mechanics of elastic collisions and energy transformations have been shared.
Some participants mention references to specific textbooks for further understanding, indicating a potential gap in the problem's presentation or the resources available to the original poster.
neeraj93
A ball of mass 2m is moving with a velocity Vo collides elastically and head-on with another ball of mass m at rest.
Find the minimum kinetic energy of the system.
K = 1/2 mv2
I personally do not understand what is expected of me here. The answer expected is
(2mVo2)/3.
But collision is elastic. And I have to find the Kinetic energy of the system. Won't the Kinetic energy of the system remain constant (mVo2) throughout?
Yes, it should be constant. I suspect the question meant something else, or the answer is wrong.
Yes, the kinetic energy remains constant, but a more close look tells you that, the 'initial' and 'final' kinetic energies are same, i.e. during a collision (for the split second when they are in contact), the kinetic energy is not conserved. The reason is as follows:
Consider a spring attached to the body initially at rest.
During collision, the spring is deformed, and at the same time, the body at rest gains speed, while the body which was moving initially is slowed down, also the spring gets compressed.
Now, a time will come, when both the bodies will travel with same velocity, and the compression in the spring would be max. or the energy stored in the spring will be max. Later on, the body with spring will gain much more speed than the other and speed away.
So, you can see that some part of the kinetic energy was stored in the spring as its potential energy. But, later it again converted to their kinetic energies.
Similarly, in bodies, there's some deformation (similar to spring, although for a short while), and as a result, some potential energy is gained(at the cost of kinetic energy).
Momentum can be conserved anytime, as the spring(or contact) force acts on both the bodies equally in opposite directions, and as a system, there's no external force.
For your answer,
Initial momentum = 2mv0
Final mometum(when they are traveling with common velocities (vc))
= 3mvc
So, vc = (2/3)vo
KE of system (sum of KEs of two mases) = (2/3)mvo2
Since you are an Indian (so am I)...I suggest you read up HC Verma part 1 Pg. 145 for better understanding...good luck...btw, u in 11th now, preparing for IIT, right?
Well, I am in 12th now, giving IIT this year...
Oh, It isn't there in Resnick, so no wonder. I, personally, don't prefer using Verma.. I'll have a look, but. thanks.
I'm in 12th too, btw.
oh...ok...all the best for your boards n all !
Thanks, good luck to you too!
  • · Replies 41 ·
  • · Replies 22 ·
