Sagnac Effect and Special Relativity
The discussion centers around the Sagnac effect and its implications for special relativity, particularly in the context of light propagation in rotating frames. Participants explore whether the Sagnac effect contradicts the constancy of the speed of light as stated in special relativity, examining various scenarios and mathematical representations.
  • One participant claims that the Sagnac effect contradicts special relativity by suggesting that light hits a rotating observing arm at speeds of c+v or c-v, questioning the constancy of c.
  • Another participant argues that the speed of light remains c in inertial frames, while in non-inertial (rotating) frames, the speed can vary, aligning with special relativity's predictions.
  • A participant presents a MAPLE worksheet to demonstrate that the Sagnac effect does not imply an inconstancy in the speed of light.
  • Some participants discuss the local velocity of light, asserting that it is always measured as c, even for rotating observers, but note that the Sagnac effect involves measuring light over a distance that varies due to motion.
  • One participant describes an experimental setup involving mirrors and a rotating frame to illustrate the time difference in photon arrival times without invoking special or general relativity.
  • Questions are raised about the nature of light used in experiments related to the Sagnac effect, specifically mentioning lasers.
Participants express differing views on whether the Sagnac effect contradicts special relativity, with some asserting that it does not while others maintain that it raises questions about the constancy of light speed. The discussion remains unresolved with multiple competing perspectives.
Participants reference various mathematical formulations and experimental setups, but there are unresolved assumptions regarding the implications of the Sagnac effect and the conditions under which light speed is measured.
KingNothing
http://www.mathpages.com/rr/s2-07/2-07.htm
Today I met a man who was claiming that the Sagnac effect, particularly in the case of light moving in a circular pattern with a rotating observing "arm" as in the first figure in the link, is contrary to special relativity. He claimed that since the wave will hit the observing arm at a rate of c+v or c-v, that this contradicts the constancy of c.
Now, in my head, I am thinking that this speed of c+v is what we observe from our inertial system which holds the axis of the roation constant, but that an actual observation device placed on the arm would still observe the incoming light as having a speed of 3*10^8 m/s.
Is this to be explained by a slight time dilation, making the time difference in the frame of the observer located on the moving arm equal to the time difference observed by us in the reference frame holding the axis constant?
[tex]y = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]
Actually, I have been staying up all night working on this problem. I will post the solution when I am finished.
I've made a brief MAPLE worksheet demonstrating just one calculation to show that the Sagnac effect does not imply an inconstancy in the speed of light. Please see the attached PDF.
I think you have it backwards. Inertial frames always observe light traveling at c. In the rotating (non inertial) frame the speed of light can vary. That is what SR says and has been observed so far.
The webpage you quoted contains the time correction in there, but good job on going through the math yourself.
Exactly. Although, the LOCAL velocity of light is allways equal to c, even for rotating and accelerating observers. That is, if you measure the velocity of light traveling NEAR you, you will allways get c. But in the Sagnac effect you don't measure the local velocity of light.
See also Sec. 6 of
http://xxx.lanl.gov/abs/gr-qc/9904078 [Phys.Rev. A61 (2000) 032109]
What is the structure that is described (propagating) in Special Relativity (Maxwell's equations?). Is there an induction experiment that emits light?
amyfrog said:
What light is used?
A laser
The Sagnac effect does not make any statement about SR nor does it depend upon GR for an explanation. You can get a time difference by setting up 4 mirrors each at the corner of a rectangle at an angle of 45 degrees - now put a source/receiver in one leg of the path so two beams travel in opposite directions around the path - now rotate the entire frame about an axis perpendicular to the plane of laser path(s) and there will be a difference in the time between the arrival of the photons because one photon has had to travel a longer distance to reach the moving receiver - but the same follows if you don't rotate the experiment, but simply move the transceiver linearly along one leg relative to the frame of the mirrors - the beam which is reflected by the mirrors in the clockwise direction will take a different amount of time than the counter-clockwise beam because one beam has to travel further to catch the receiver than the other
  • · Replies 40 ·
  • · Replies 33 ·
  • · Replies 57 ·
  • · Replies 26 ·
  • · Replies 35 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 32 ·
  • · Replies 20 ·
