Thread Closed
Launch a ping pong ball. A little help...
Share Thread Thread Tools
Mar4-10, 03:19 PM   #1
Jps
Hello all,
Basically we need to come up with a planar bistable mechanism that will launch a ping pong ball. Here's a quick image I made: http://freewebsite.0nyx.com/images/mech.html
The club link is supposed to hit the ping pong ball and the goal is to make it go as horizontally far as possible.
By bistable it means that the mechanism must have two positions with unstable equilibrium position of max. energy storage somewhere in between. The mechanism is triggered with a slight push to the club link.
So how do I approach this problem. Say I know that the length between two pivots is 2 inch. And I'm supposed to figure out the dimensions of the links and what type of spring to use. If someone can throw some background info to this mechanism or some equations for energy storage of spring etc. will be helpful.
Thank you.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar5-10, 06:33 AM   #2
For my project I used a rat trap ballista (so called catapult) To get the energy Iwas suposed to use Mohr's circle because of the orientation of the spring. But you should be able to use the energy version of Hooke's law.
The way I cheated my lecturer was to set the device up vertically and I proved the potential energy by the change in static height maintained by the spring for different weights hung off it. Hope this helps.
Thread Closed
Thread Tools
Similar Threads for: Launch a ping pong ball. A little help...
Thread Forum Replies
Ping Pong ball vs. golf ball and distance moved General Physics 11
ping pong ball aerobatics General Physics 0
ping-pong ball launcher Engineering, Comp Sci, & Technology Homework 1
Ping pong ball launcher Mechanical Engineering 5
Ping Pong ball launcher Classical Physics 1
