Calculating diamter of wire that will blow if current exceeds 1A
  • Thread starter Thread starter Linus Pauling
    Current Wire
The discussion focuses on calculating the diameter of a wire fuse designed to blow at a current exceeding 1.0 A, utilizing a material that melts at a current density of 500 A/cm². The formula J = I/A is applied, where J represents current density, I is current, and A is the cross-sectional area. The correct calculation yields a radius of 0.00252 m, leading to a diameter of 0.005 m or 5.0 mm. A correction was noted regarding unit conversion from cm² to m², emphasizing the importance of accuracy in calculations.
  • Understanding of electrical current and current density concepts
  • Familiarity with the formula J = I/A
  • Basic knowledge of unit conversions, particularly between cm² and m²
  • Experience with fuse design and material properties
  • Research the properties of different fuse materials and their melting points
  • Learn about the implications of current density in electrical engineering
  • Explore advanced calculations for fuse design, including safety margins
  • Study the effects of temperature on wire resistance and fuse performance
Electrical engineers, hobbyists designing fuses, and students studying electrical circuits will benefit from this discussion.
Linus Pauling
Calculating diamter of wire that will "blow" if current exceeds 1A
1. You need to design a 1.0 A fuse that "blows" if the current exceeds 1.0 A. The fuse material in your stockroom melts at a current density of 500A/cm^2.
2. J = I/A
3. J = 500A/m^2 = 50000A/m^2 = 1.0A / (pi*r^2)
r = sqrt[1/50000*pi] = 0.00252 m
diamter = 2*r = 0.005 m = 5.0mm
That is incorrect (answer in mm).
Hi Linus Pauling! :smile:
(try using the X2 tag just above the Reply box :wink:)
You didn't use enough zeros to convert from cm2 to m2 :wink:
(but why bother? why not leave it as cm??)
ahh cripes. thanks for the catch... i always do that. :)
  • · Replies 16 ·
