Band bending in a thin film semiconductor
The discussion centers on the phenomenon of band bending in thin film semiconductors, specifically passive films formed on stainless steel through electrochemical methods. The user asserts that band bending occurs at the interface of the passive film and the electrolyte solution, supported by Mott-Schottky measurements indicating a carrier density of 1020-1021 cm-3. A contrasting opinion suggests that due to the nano-scale thickness of 4-15 nm, band bending may not occur. However, the user's experimental results affirm the presence of band bending in this context.
  • Understanding of semiconductor physics, particularly band theory
  • Familiarity with electrochemical methods for thin film formation
  • Knowledge of Mott-Schottky analysis for semiconductor characterization
  • Basic principles of n-type semiconductors and their behavior
  • Research the principles of band bending in semiconductor physics
  • Study Mott-Schottky analysis techniques and their applications
  • Explore electrochemical methods for thin film deposition
  • Investigate the effects of film thickness on semiconductor properties
Researchers in semiconductor physics, electrochemists, and materials scientists focusing on thin film applications and corrosion studies in stainless steel.
fuelcell
Hello!
There're very thin (4-15 nm) semiconductor films (passive film) formed on stainless steel by electrochemical method. In a electrochemical cell, I applied potential on stainless steel electrode to adjust Fermi level of the semiconductor passive film. I think that band bending take place in the semiconductor passive film (at the interface of passive film/electrolyte solution).
However, one of my friend think there would be no band bending in the thin layer (4-15 nm level), due to the nano-scale.
I think there's band bending take places. But I don't know his view point is right or not, please help me. Appreciate all answers!
fuelcell said:
Hello!
Sounds more like schoolwork than a friendly debate at the local pub. We don't answer schoolwork questions here for you, but can try to help if you seem to have done much of the work.
What course is this for? What is your textbook, and what other learning resources are you given in the course? Is this a lab class, or mostly textbook-based?
What semiconductor are you using, at what doping level, and how are you making contact to it?
Thank you, Berkeman.
It's a stainless steel corrosion research in a lab. The passive films consist of Fe/Cr oxide, behave n-type semiconductor. One side of the passive film contact with stainless steel, the other side contact with aqueous solution. According to the Mott-Schottky measurement result, band bending must take place at the interface. The carrier density is 10E20-10E21 cm-3 level.
I don't know if there's a theory supporting his view point - band bending can not take place in a thin layer semiconductor due to the nano-scale.
  • · Replies 0 ·
20K
