Soils, mud, dirt Sticking to glass?
  • Context: Undergrad
  • Thread starter Thread starter dpg1
    Glass
The discussion centers on the issue of soil, mud, and clay particles adhering to glass surfaces during horizontal flow in a tube. Key factors identified include electrostatic forces and gravity, with specific recommendations for mitigating particle adhesion. Using a salt buffer, such as 300 mM NaCl or KCl, can effectively screen electrostatic charges. Additionally, fetal bovine serum (FBS) is suggested as a means to prevent particle sticking by utilizing protein interactions.
  • Understanding of fluid dynamics and particle suspension
  • Knowledge of electrostatic interactions in colloidal systems
  • Familiarity with buffer solutions and their compositions
  • Basic principles of sonication and its applications
  • Research the effects of ionic strength on particle stability in suspension
  • Explore the use of fetal bovine serum in various suspension applications
  • Investigate sonication techniques for improving particle dispersion
  • Learn about the role of electrostatic forces in colloidal stability
Researchers and engineers working with fluid dynamics, materials science, or any professionals dealing with particle suspension in glass systems.
dpg1
Soils, mud, dirt "Sticking" to glass?
Hi all,
First of all, please feel free to move this question wherever it should go. I truly have no idea if I'm looking in the right place at all, just a point in the right direction would be greatly appreciated.
My question:
For a project I'm working on, I'm required to flow a sample of soils/mud/clay/dirt suspended in either water or a buffer through a glass tube horizontally. Of course, often gravity has it's way and particles sink to the bottom and stick to the bottom of the tube. This is of course expected with big particles, but smaller particles (to give an idea of scale - less than microns) should be pushed along by the flow of the solution? However, they still stick to the bottom. My question is - what are the forces involved? Electrostatic charge? Or is it just good old gravity? It's way out of my area, so as I say, any help, any point in the direction would be greatly appreciated.
Many thanks,
David
It's electrostatic. There's a couple quick fixes to try: 1) instead of water, try a salt buffer: the salt will screen the charges, 300 mM NaCl or KCl is a good starting point. 2) I use fetal bovine serum to help prevent PS or PMMA microspheres from sticking to glass surfaces; the proteins in FBS seem to stick first (via electrostatic interactions), and that helps the particles from sticking.
It's not a trivial problem to solve, if that helps. Sonication may be useful, but may not be practical for your application.
  • · Replies 24 ·
