How Do You Calculate the Volume of a Solid Revolved Around the Y-Axis?
The volume of a solid revolved around the Y-axis, defined by the area under the curve e^x - 1 and bounded by y=1, x=0, and x=ln2, can be calculated using the shell method. The correct integral setup is 2π∫₀^(ln2)x(1 - (e^x - 1))dx. The integration process involves using integration by parts, leading to the expression e^x(x - 1) - x² evaluated from 0 to ln2. The final volume is confirmed to be 2π(ln2 - 1)², correcting the initial miscalculation of constants during integration.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the shell method for calculating volumes of solids of revolution.
  • Knowledge of exponential functions and their properties.
  • Ability to perform integration by parts.
  • Study the shell method in detail for calculating volumes of solids of revolution.
  • Practice integration by parts with various functions, focusing on exponential functions.
  • Explore advanced topics in calculus, such as multiple integrals and their applications in volume calculations.
  • Review common mistakes in integration to avoid errors in future calculations.
Students and professionals in mathematics, particularly those studying calculus and volume calculations, as well as educators teaching integration techniques and solid geometry.
James889
Hi,
The area
[tex]e^x-1[/tex]
Is rotated about the y axis, bounded by y=1, x=0 and x=ln2 find the volume of the solid.
And i am clearly making something wrong, so if anyone could verify my work.
[tex]~ 2\pi\int_0^{ln2}x\cdot(1-(e^x-1)[/tex]
[tex]-2\pi\int_0^{ln2}xe^x-2x[/tex]
Integration:
u=x, du=1
dv=e^x, v=e^x
[tex]\int xe^x -2x= xe^x -e^x -x^2[/tex]
[tex]e^x(x-1)-x^2\bigg|_0^{ln2} = 2\pi \cdot ln2-1 -(ln2)^2[/tex]
The answer is supposed to be [tex]2\pi(ln2-1)^2[/tex]
Thanks!
where did that 1 come from in your shell method formula?
When you integrate you should obtain : 2*pi*(ln22-2*ln2+1)
That then can be the factored to the book's answer.
You lost a 2 with the ln2
  • · Replies 27 ·
  • · Replies 20 ·
