| Thread Closed |
A Quantum Mechanical model of measurement |
Share Thread | Thread Tools |
| Mar10-10, 05:23 PM | #1 |
Following a short discussion in another thread, I promised to start a new thread for this.
I asked myself the question "how would I describe the process of measurement in a fully quantum mechanical way?" and came up with this. 1) A model for the general measuring device The aim is to have a QM system which describes a measuring device, with a finite dimensional space of states so that the whole thing can be written down with finite matrices. I imagine a dial, with a pointer (see picture coming soon). Any position of the pointer corresponds to a different quantum mechanical state for the pointer (much like a 1-d particle on a ring). To make things easier, discretise the possible positions of the pointer, so that we have N possible pointer states, all equally spaced. Assume that the Hamiltonian for the dial is H = 0 so there is no dynamics at all. So the measuring apparatus is an N-state quantum system. 2) Operators for the measuring device. There is only one operator we need for the measuring device: the operator that moves the pointer. By analogy with the momentum operator, we want the generator of pointer rotations, which I will call R. Define it so that the unitary matrix exp(-iR) advances the pointer clockwise by pi radians. So far so good, we have a device which we can start in the state pointing to 0, and we have an operator which rotates the pointer round by whatever angle we want. We can calibrate the device by letting the maximum reading be 'm', corresponding to pi radians. 3) Performing a measurement of the number '4'. Suppose we want to measure a number, called y, using our device, the way to do it is: In units where hbar = 1, change the hamiltonian to H = R y/m for a duration of 1 unit of time, then change back to H = 0. The time evolution operator will be exp(-i(y/m)R), which will swing the pointer round by (y/m) of a half circle. Eg, we might choose m = 20, with N = 40, so the states on the dial run from -19,-18,....0,...19,20. Acting on the initial state with exp(-i(4/20)R) will move the pointer to point at '4'. ie, we have measured the number 4 using our measuring apparatus. [EDIT at 9am GMT: Despite numerous replies already, I will continue from here, but address concerns in a reply below] 4) Measuring the properties of another quantum system So far we have shown how to measure a number on our dial. Now we want to measure the properties of another system. Generalising what we did to measure a number, the following procedure will 'measure' the value of observable [tex]\hat O[/tex]. (I've put the hat on it so it doesn't look like zero). The full hamiltonian, which acts on the product space [tex]{\mathcal H}_M\otimes{\mathcal H}_S[/tex] will initially be [tex]H = \mathbf 1 \otimes H_S[/tex] since our measuring device has H=0. Now turn on the measurement hamiltonian. Again, 'm' sets the maximum reading on the dial. [tex]H_{meas} = \frac{1}{m\tau}R\otimes \hat O[/tex] After time tau, set the measurement hamiltonian back to H = 0. Ideally, our clever experimentalist is able to make 'tau' very short, so we have an instantaneous measurement. 4a) Explicit example, measuring the energy of an harmonic oscillator. Suppose the maximum reading on my dial is 3, and I have N = 12. Label the states of the apparatus by [tex]|-2.5\rangle,|-2.0\rangle,|-1.5\rangle,\ldots|0.0\rangle,\ldots,|2.5\rangle,|3.0\rangle [/tex]. Also, suppose the system we are interested in is a Harmonic oscillator, currently in the state [tex]\frac{1}{2}|0\rangle+\frac{1}{\sqrt{2}}|1\rangle+\frac{1}{2}|2\rangle[/tex]. Therefore the inital state of the composite system is the product state: [tex]|0.0\rangle \otimes [\frac{1}{2}|0\rangle+\frac{1}{\sqrt{2}}|1\rangle+\frac{1}{2}|2\rangle][/tex] Now the experimentalist comes along, and attaches his measuring device to the harmonic oscillator in such a way as to measure the energy. The effect of this is that the measurement hamiltonian becomes [tex]H_{meas} = \frac{1}{m\tau}R\otimes H_s[/tex]. After time tau (which is much shorter than the period of the oscillator), he disconnects the measuring device. The final state of the composite system is [tex]\frac{1}{2}|0.5\rangle \otimes |0\rangle+\frac{1}{\sqrt{2}}|1.5\rangle \otimes |1\rangle+\frac{1}{2}|2.5\rangle \otimes |2\rangle[/tex] The apparatus state is now entangled with the measured state. *So the readings on the apparatus are the eigenvalues of the observable. *Moreover, the state of the system is the eigenvector for the measured value. Crucially, the apparatus states are orthogonal, so there is no interference possible between the two options for the system. Applying the probability interpretation to the entangled system is consistent with applying it to just the system we measured originally, except the measuring process and apparatus are described in a QM way too now. I believe the points with (*) were the points in the other thread under point 2, which I wanted to address. 5) Generalisations. This is completely general. My measuring apparatus will measure any observable you like and in performing the measurement, it is clear why only eigenvalues are allowed, and why eigenvectors is what you get afterwards. [edit: more may need to be edited if it is unclear, but I thought it better to have all of it in one place if there is going to be a discussion] |
| Mar10-10, 06:16 PM | #2 |
There is no big breakthrough in this attempt, it is just decoherence
| Mar10-10, 07:17 PM | #3 |
Recognitions:
This thread was started by peteratcam to give his perspective on that point, and I for one am eager to see it. |
| Mar10-10, 07:47 PM | #4 |
I am pleased to agree with Spectracat (for a change). Could we not refrain from the scoffing and give the man a chance to make his point?
| Mar11-10, 12:51 AM | #5 |
I do not agree that Bell's FAPP purpose argument holds. There is no established general mathematical theorem to prove either side of the argument. I will let Spectracat answer, as indeed it is not a short and straightforward argument, but it is discussed at length in the decoherence literature, for instance Omnes "The interpretation of quantum mechanics" (Princeton 1994) 7.7 where one can find the core of the discussion, preceded and followed by many explicit calculations and numerical estimates. Decoherence has also been measured in the lab, and agree with those estimates.
Bell's arguments holds at a quite general level, if one is willing to accept as a postulate that every observable can be measured in principle. Since it is quite an interesting discussion, but too long for me to go into right now, I will just copy below some parts of Omnes' conclusion in chapter 12 section 7 to the question "can one circumvent decoherence ?" |
| Mar11-10, 02:35 AM | #6 |
Mentor
| Mar11-10, 03:26 AM | #7 |
I wrote some (possibly relevant) thoughts about the QM measurement problem in http://physicsforums.com/showpost.ph...41&postcount=4
Eugene. |
| Mar11-10, 03:40 AM | #8 |
(I have now finished the original post)
| Mar11-10, 03:48 AM | #9 |
Fredrik's reply was written before I had finished the exposition in the original post, but I will reply to it.
I don't claim the Hamiltonian is changed *at random*. Rather, a clever experimentalist arranges his levers, electrical wires, and filters, such that the hamiltonian which describes the interaction between the system and the apparatus is one which will measure the desired outcome. It is what happens all the time in labs. |
| Mar11-10, 05:16 AM | #10 |
Mentor
| Mar11-10, 05:24 AM | #11 |
| Mar11-10, 01:04 PM | #12 |
So why outcome is different in identical setups, when people measure the same observables?
| Mar11-10, 02:11 PM | #13 |
| Mar11-10, 02:21 PM | #14 |
No, QM itself does not predict it, because QM math and Decoherence are deterministic.
Now, when collapse int are ruled out, we have non-collapse interpetations (+macroscopic realism aka shut up and calculate). Decoherence removes non-diagonal elements, but it does not tell us what outcome is "real". All non-collapse interpretations must provide a mechanism to resolve that issue. Using hidden variables (BM) or by claiming that all outcomes are real (MWI). You can not, in principle, derive non-deterministic view of the world from deterministic QM without some sorts of additional assumtions (well, in MWI these assumptions are null, but anyway...) |
| Mar11-10, 02:28 PM | #15 |
I tried to pinpoint the problem:
Born rule is either predicted (BM) or denied (but accepted FAPP) in MWI. Both theories are deterministic. |
| Mar11-10, 02:57 PM | #16 |
Mentor
Peteratcam, your approach is just von Neumann measurement theory, as I initially suspected. The time evolution that you describe is sometimes called a "premeasurement". It's just an interaction that creates a correlation between states of the measuring device and states of the system. von Neumann didn't know this of course, but the actual measurement is a second interaction between the measuring device and its environment that makes the the system FAPP indistinguishable from a mixed state (i.e. a state that has "collapsed" into one of the alternatives).
I think you would find this article interesting, at least the first few pages. I'm too tired right now to try to explain the consequences of what he's saying there, so you'll have to read it for yourself (if you're interested). |
| Mar11-10, 03:06 PM | #17 |
Eugene. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: A Quantum Mechanical model of measurement
| Propagating Measurement Uncertainty into a Linear Regression Model | Set Theory, Logic, Probability, Statistics | 5 | ||
| mechanical mass-spring-damper model from IV curve | Electrical Engineering | 7 | ||
| Model that demonstrates conservation of mechanical energy | Introductory Physics Homework | 5 | ||
| Quantum measurement? | Quantum Physics | 23 | ||
