Matrix Elements: J_+*J_- = J^2 - J_z^2+hbarJ_z?
  • Context: Graduate
  • Thread starter Thread starter Nusc
    Elements Matrix
The discussion revolves around the mathematical expressions involving angular momentum operators, specifically the relationship between the raising and lowering operators (J_+, J_-) and the total angular momentum operators (J^2, J_z). Participants explore the implications of these operators in the context of quantum mechanics, particularly for different spin states.
  • Some participants assert that J_+*J_- can be expressed as J^2 - J_z^2 + hbarJ_z, questioning the validity of this expression in various contexts.
  • There is a discussion regarding the application of the lowering operator S_- to a state |j,m>, with some participants stating that S_-|j,m> = |j,m-1>.
  • Participants inquire about the nature of the constant that appears when applying angular momentum operators, with some suggesting that it should be considered in the context of eigenstates.
  • There are questions about the eigenvalue h^2 in the expression S_-S_+|+->, with some participants discussing the implications of applying angular momentum operators to quantum states.
  • Some participants express confusion about the relationship between the operators and their results, particularly regarding spin 1/2 and spin 3/2 particles.
  • There are references to specific equations and results from literature, with participants debating their correctness and the presence of missing factors of hbar.
Participants do not reach a consensus on the expressions involving the angular momentum operators, with multiple competing views and interpretations remaining throughout the discussion.
Some participants note that the expressions discussed are operators and that their results depend on the states they are applied to. There is also mention of potential missing factors of hbar in various expressions.
This discussion may be of interest to those studying quantum mechanics, particularly in the context of angular momentum and spin states, as well as those looking to clarify the application of angular momentum operators in quantum systems.
Nusc
Well, [itex]\langle j,m|S^2_{-}|j,m\rangle=\langle j,m|(S^2_{-}|j,m\rangle)[/itex] and [itex]S^2_{-}|j,m\rangle=S_{-}(S_{-}|j,m\rangle)=[/itex]___?
Normally J_+*J_- is substituted as J^2 - J_z^2+hbarJ_z
As described above, J_+(J_-J_+), wouldn't the content in parenthesese just cancel out to 1 ?
I am going to need you to define some terms there. What is S-, the lowering operator for spins? What is j? Is it the generic total angular momentum quantum number, or is it for a specific case, such as an atom, where you are considering the coupling of orbital angular momentum (l) to spin (s)? Are you dealing specifically with states of spin 1/2 particles, or is it a generic case?
Yes.
j is the generic total ang mom
Spin 1 particle
Yes.
General
Spin 1 particle
So what happens in general when the spin lowering operator is applied to a state |j,m>? What are the properties of the scalar product of two angular momentum states?
Answer those questions and you will have your answer.
S_-|j,m>=|j,m-1>
S_+|j,m-1> = |j,m> Is that right? Back to my question, J_+*J_- is substituted as J^2 - J_z^2+hbarJ_z which isn't 1. why is this?
<j',m'|S_+^3|j,m> = c_jm^+c_jm+1^+c_jm+2^+<j',m'|j,m+3> delta_j',j delta_m',m+3
MY secnod question is the following
S_-S_+|+-> = h^2 |-+>
Where does the eigenvalue h^2 come from?
Nusc said:
S_-|j,m>=|j,m-1>
Close, there should be a constant multiplying the state on the rhs of each equation above. But anyway, that isn't what you posted originally .. your expression from your OP has two applications of the lowering operator ...
just to clarify, I guess you mean:
[tex]J_{+}J{-}=J^{2}-J_{z}^{2} + \hbarJ_{z}[/tex]
That is correct, but why would you think it equals one in the general case? That expression is an operator, so you should look at what it does to a state ... since any angular momentum eigenstate of each of the operators in that expression, this is pretty trivial:
[tex][J^{2}-J_{z}^{2} + \hbarJ_{z}]|j,m> = J^{2}|j,m>-J_{z}^{2}|j,m> + \hbarJ_{z}|j,m> = \hbar^{2}[j(j+1) - m^{2} + m]|j,m>[/tex]
Not sure what that last expression has to do with anything, but FWIW it looks basically correct (although it could do with some tex formatting :wink:.
What constant are you referring to?
I don't really understand that ... what is |+->?
In any case, hbar is the quantum mechanical unit of angular momentum. So the result of applying any angular momentum operator to a quantum state will always be multiplied by hbar. In the case above, the operator is a product of two angular momentum operators, so you get hbar*hbar from the application of that operator to a state.
+ spin up
- spin down
Do you know how S_z would act on such a state given what I said earlier?
In addition
S_+S_- |+-> = 0
S_z^-*S_z^+|+-> = ?
it supposed to be -hbar^2/4 not sure why.
And just to clarify, S_-*S_+ = 1 without constants?
ALso:
S_+S_- + S_-S_+ = S^2-S_z^2 but this book I found says its also equal to 1 for a spin 1/2 particle?? Why?
They also have
S_+S_z = -1/2 S_+
why is that one true?
No, ... you gave the correct expression for this *operator* earlier ... I showed you how to apply it to an eigenstate. It most certainly does not equal one.
EDIT: However, since I now know you are talking about spin 1/2 eigenstates, I think you will find that the result of applying this to the eigenstate will give you 1, (well, actually hbar2, as I have said).
Did you check out the website I linked?
Nusc said:
ALso:
Again, those are operators on the right hand side .. a spin 1/2 particle is an eigenstate of both of those operators ... plug in the state and evaluate the expression. However, it does not evaluate to one when applied to a spin 1/2 eigenstate .. work it out and see what you get. You are missing some factors of hbar in there as well.
They also have
S_+S_z = -1/2 S_+why is that one true?
again, missing some factors of hbar ... and that is a possible result, but not the only one.
SpectraCat said:
Again, those are operators on the right hand side .. a spin 1/2 particle is an eigenstate of both of those operators ... plug in the state and evaluate the expression. /QUOTE]
Is the same true for a spin 3/2?
