Two divergent series whose minimum converges?
The discussion centers on finding two divergent series, \( \Sigma a_n \) and \( \Sigma b_n \), such that the series of their minimum terms, \( \Sigma \min(a_n, b_n) \), converges. The proposed sequences are \( a_n = 1, 4, 4, 16, 25, 25, 25, 25, 25, 25, 25, 144, 169, 196, \ldots \) and \( b_n = 1, 1, 9, 9, 9, 36, 49, 64, 81, 100, 121, 121, 121, 121, \ldots \). Both sequences are positive and decreasing, leading to the conclusion that the series of minimum terms converges to the square harmonic series. This approach effectively meets the stipulation that both series must remain positive and decreasing.
  • Understanding of series convergence and divergence
  • Familiarity with harmonic series
  • Knowledge of positive and decreasing sequences
  • Basic mathematical notation and terminology
  • Research the properties of the square harmonic series
  • Explore algorithms for generating divergent series
  • Study the implications of the floor function in series
  • Investigate other examples of converging minimum series
Mathematicians, students studying series and sequences, and anyone interested in advanced convergence concepts in mathematical analysis.
coffeetheorem
I am struggling to find two divergent series, \Sigmaan and \Sigmabn, such that the series of minimum terms, \Sigmamin{an,bn}, actually converges.
A further stipulation is that both an and bn must be positive, decreasing sequences. (Otherwise the problem is trivial, as one could simply alternate 1/n and 1/n^2 to achieve the desired result.)
Here's one way. For concision I'm just going to list the reciprocals of the terms:
Code:
{a_n} = 1  4  4 16  25  25  25  25  25  25   25 144 169 196 ...
{b_n} = 1  1  9  9   9  36  49  64  81 100  121 121 121 121 ...
Clearly these are positive and decreasing, and the series of minimum terms is the square harmonic series, which converges. But we let the two series take increasingly long "turns" being constant, long enough that each can be seen to be at least as large as the harmonic series.
For instance, the bottom series needs to stay long enough at 1/121 so that the part after 9,9,9 (which corresponds to 1/3) sums to at least (1/4).
Thanks, boss!
I had attempted a pair that was similar, but too simple and not quite workable. Here's what I initially tried (in reciprocal):
a_n = 1+9+9+ 9+ 25+25+25+25+25+49+49+49+49+49+49+49+81 … (nine times) …
b_n = 4+4+16+16+16+16+36+36+36+36+36+36+64 … (eight times) …
Then a_n is (2k+1)/(2k+1)^2 = 1/(2k+1), b_n is 2k/(2k) ^2 = 1/2k,
but the sequence of minimum terms is [k/2]/k^2 (where [k/2] denotes the floor function), which is approximately 1/2k.
Your sequences seem to be neatly-defined, letting each "go out far enough" to get the next term in the (basic) harmonic series. I would be hard pressed to find a closed-form expression for them, although I'd think it would be easy to define them algorithmically.
Another would be to let a_n=1/n, b_n=1 if n odd, b_n=-1/n if n even.
arildno: Part of the stipulation of the problem is that both sequences must be positive and decreasing. I have edited the original post to clarify this.
  • · Replies 17 ·
