Not really HW Just want to fully understand induced emf
This discussion centers on the principles of electromagnetic induction, specifically examining the results from a lab experiment involving a magnet dropped through a coil connected to a voltage sensor. The experiment demonstrated Faraday's law of induction, resulting in an induced electromotive force (emf) with a high point area of 0.021 VoltSec and a low point area of -0.020 VoltSec. The negative value indicates a reversal in current direction as the magnet exits the coil, aligning with Lenz's law, which states that induced currents oppose changes in magnetic flux. Understanding the right-hand rule is essential for determining the direction of the induced current.
  • Understanding of Faraday's law of induction
  • Familiarity with Lenz's law
  • Knowledge of magnetic flux and its relation to induced emf
  • Basic grasp of the right-hand rule for electromagnetic phenomena
  • Study the mathematical formulation of Faraday's law: {Emf} = -N(dφ/dt)
  • Explore the implications of Lenz's law in various electromagnetic scenarios
  • Investigate the right-hand rule and its applications in determining current direction
  • Conduct experiments to observe the effects of varying magnet speeds on induced emf
Students and educators in physics, particularly those focusing on electromagnetism, laboratory technicians conducting experiments on electromagnetic induction, and anyone seeking to deepen their understanding of induced emf and its practical applications.
sarahjt1
Ok... so there really isn't a homework problem that goes directly with what I am asking... I just want to understand how/why induction (magnet through a coil) gave certain results in our Science Workshop program...
Here is what we did in our lab:
We dropped a magnet (south end in first) through a coil hooked up to a voltage sensor and photogate to measure the area of our emf vs. time plot. We didn't do any calculations the computer did... but it used the concept of Faraday's law of induction. The resulting graph had a high point and a low point.
The high point's area beneath the curve was 0.021VoltSec
The low point's area above the curve was -0.020VoltSec
I understand that the area's have to be equal because Lenz's law states something to the effect that whatever change we've made we have to give back.
BUT What I don't fully understand is WHY it is a negative value? Is it because the current flow changes direction?
I don't fully understand the right hand rule either and I don't know exactly which direction the current was flowing as the south end of the magnet entered the coil... but I do know that it will reverse direction once the magnet is leaving the coil and that the point on the graph that y=0 (voltage) is the point when the current is reversing.
Basically, I want to conceptually understand the theory and how it is applied to the lab we did... here is the lab guide http://physics.unr.edu/152labs/Magnetic_Induction.pdf
The direction of the induced electric field changes as the direction of the magnetic field changes, which causes the induced current direction to change.
Apply Faraday's law:
[tex]{Emf} = -N\frac{d\phi}{dt} = -NA\frac{dB}{dt}[/tex]
Working out dB/dt is complicated. All you have to know is that as B changes direction so does dB/dt and, therefore, so does the emf.
AM
When the magnet is above the coil, and starts to fall down, approaching and entering the coil, the magnetic flux increases inside the coil. Increasing flux induces voltage according to Faraday's law of induction.
When the magnet traverses the coil the flux does not change much and the the induced voltage gradually drops to zero. The situation changes when the top end reaches the coil. As it the magnet leaves the coil, the flux gradually disappears and the induced voltage has opposite charge.
The shape of the curves is related to the speed of the falling bar.
When is this speed higher, when the magnet enters or when it leaves the coil? What do you think how does the induced field depend on the speed of the magnet?
ehild
