Thread Closed
Magnetic field generated by current in semicircular loop at a point on axis
Share Thread Thread Tools
Mar13-10, 10:11 PM   #1
Determine the magnetic field strength and direction at a point 'z' on the axis of the centre of a semi-circular current loop of radius R.
2. Relevant equations
Biot Savart Formula
[tex]d\vec{B}=\frac{\mu_{0}Id\vec{r}\times\hat{e}}{4\pi|\vec{R}-\vec{r}|^{2}}[/tex]
e being the unit vector from r to R
3. The attempt at a solution
A much simpler problem is a full current loop, because one component of the magnetic field cancels out. For this problem, you'd have to deal with the half-circle arc and the straight line base separately. I was also wondering whether its easier to calculate the z and x components of B separately as well... One component is straightforward enough... I just really don't understand where to start.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar14-10, 12:15 AM   #2
Recognitions:
Homework Helper Homework Help
This should be a pretty straightforward application of the Biot-Savart Law. Start by finding expressions for [itex]\textbf{r}[/itex], the position vector for a general point on the semi-circular arc, and [itex]\textbf{R}[/itex] the position vector for a general point on the [itex]z[/itex]-axis....what do you get for those?...What does that make [itex]\hat{\mathbf{e}}[/itex]? What is [itex]d\textbf{r}[/itex] for a semi-circualr arc?
To makethings easier, you will want to use cylindrical coordinates.
Mar14-10, 03:23 PM   #3
So, the parametric representation of a point on the semi-circle would be (0, bcos(t), bsin(t)) where b is the radius of the semi-circle.
The vector R is just [d, 0, 0] where d is the distance on the axis of the point
and then the e is the unit vector from R-r
But what's dr? And where does the switch to cylindrical coord come in?
Mar14-10, 04:34 PM   #4
I think I got it. Thanks
Mar14-10, 11:19 PM   #5
Recognitions:
Quote by SOMEBODYCOOL View Post
If you'd like to post your result, we''ll be able to check it for you.
Thread Closed
Tags
biot-savart, magnetic field, magnetic fields, semi-circle
Thread Tools
Similar Threads for: Magnetic field generated by current in semicircular loop at a point on axis
Thread Forum Replies
Off-axis Magnetic Field of Current loop (MATLAB?) Math & Science Software 5
Current Loop Magnetic Field Introductory Physics Homework 9
Magnetic Field Current Loop Introductory Physics Homework 1
Magnetic field generated by a circular current loop Classical Physics 12
Current loop + perpendicular current : magnetic field? Advanced Physics Homework 1
