Discovering the Exact Value of sin45: A Trigonometry Homework Guide
  • Thread starter Thread starter steve snash
    Sin Value
The discussion revolves around finding the exact value of sin(45 degrees) in the context of trigonometry. Participants explore the methods for determining this value, including geometric interpretations and the use of right triangles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants question whether they are expected to memorize the values or derive them. There are suggestions to use geometric constructions, such as right triangles, to understand the sine function better. Some participants discuss the relationship between angles in a right triangle and the implications for calculating sine values.
The conversation includes various attempts to clarify the exact value of sin(45 degrees) and the methods to derive it. Some participants have provided insights into using the Pythagorean theorem and the properties of special triangles, while others express confusion or challenge certain statements made during the discussion.
There are indications of misunderstandings regarding mathematical statements, particularly in the context of the Pythagorean theorem. The discussion also reflects on the constraints of homework expectations, such as whether derivation or memorization is required.
steve snash
Which of the following is the exact value for sin45??
a) 2/(sqrt 2)
b) (sqrt 2)/2
c) 1/(sqrt 2)
d) (sqrt 3)/2
e) sqrt 2
I have no idea how to work out exact values for trig functions??
Are you expected to work it out, or just to have memorized it?
As it is, there's only a few angles for which the sine and cosine functions have exact values - 30, 45, and 60 degrees are the useful ones, and it's also possible (once knowing these) to find others such as 15 degrees.
If you're expected to work it out, try constructing a geometrical problem (like a triangle) where the sine of 45 is involved, and ask yourself which of these values sounds reasonable. Pythagoras' theorem will allow you to find the value, if you do this.
Draw a right triangle with one acute angle that is 45 degrees. What's the other acute angle?
There are only a few angles for which you can get exact values. 45 degrees is one of them, and so are 30 degrees and 60 degrees.
Yeah but how to you get the EXACT value when you work out the value of sin45 in a right angled triangle?
Dont worry i worked it out sin 45=opposite/hypotenuse
=1/sqrt2 and sqrt2/2
Well, once you've worked it out, you have the exact value.
I suppose you could draw the triangle and measure if you wanted an approximation, but if you use geometry and leave the square root in your answer then it is exact.
EDIT: Oops, you beat me to it. Well done. :)
The point is that 45+ 45= 90 so if one angle of a right triangle is 45 degrees, so is the other- and that means you have an equilateral right triangle.
Now, assume the two legs both have length 1. Then, by the Pythagorean theorem, the length of the hypotenuse, c, is given by [itex]c^2= 1^2+ 1^2= 1+ 1= 3[/itex] so [itex]c= \sqrt{2}[/itex].
You can get sin(45) and cos(45) from that.
By the way, because this will probably come up soon:
An equilateral triangle also has all three angles equal: 180/3= 60 degrees.
If you drop a perpendicular from one vertex of an equilateral triangle to the opposite side, it also divideds the opposite side into equal parts and divides the angle into two equal angles.
That is, you have two right triangles with angles 60 degrees and 60/2= 30 degrees.
If you take one of the two short legs to have length 1, the hypotenuse has length 2. You can use the Pythagorean theorem to find the length of the other leg, the perpendicular and find sin(60), cos(60), sin(30), cos(30) from that.
1+1=3, HallsofIvy? OK.
So, subtracting 1 from both sides...
1=2
Wow!
I think we all know what he meant :rolleyes: 1 + 1 = 2
1 + 1 can equal 3, but only for large values of 1. :rolleyes:
1=2
Wow!
Is there no limit to my mathematical talents?:-p
  • · Replies 21 ·
