Thermodynamics Conceptual Question
The discussion focuses on calculating the rate of change in kinetic energy for a fluid system with air flowing through a duct with two inlets and one outlet, under steady-state conditions. The relevant equation for kinetic energy is K.E. = 1/2 mv², where m is the mass flow rate and v is the velocity. The user seeks clarification on how to apply this equation to find the rate of change of kinetic energy between the inlets and the outlet, specifically using the formula d/dt(KE) = 1/2 ̇mv². This indicates a need for understanding the relationship between mass flow rates and velocities at different points in the system.
  • Understanding of basic thermodynamics principles
  • Familiarity with kinetic energy equations
  • Knowledge of mass flow rate concepts
  • Experience with steady-state flow analysis
  • Study the application of the conservation of energy in fluid dynamics
  • Learn about the Bernoulli equation and its implications for flow systems
  • Explore the concept of mass flow rate in duct systems
  • Investigate advanced topics in kinetic energy calculations in fluid mechanics
Students studying thermodynamics, engineers working with fluid systems, and anyone interested in the principles of kinetic energy in steady-state flow scenarios.
boeing9379
I have a system with air flowing through a ducting with two inlets and one exit operating at steady state. There is no heat transfer or potential energy change. I know the mass flow rates and velocities at all inlets and exits. How would I go about finding the rate of change in kinetic energy for the stream flowing from point 2, an inlet, to point 3, the outlet.
I don't know exactly what the rate of change of kinetic energy between one of the inlets and the exit means, so I don't know where to start.
Maybe the rate of change in the kinetic energies of the inlets and outlet per minute or second? [tex]K.E. = \frac{1}{2}mv^2[/tex]
Adding to what crims0ned suggested
[tex]\frac{d}{dt}(KE) = \frac{1}{2} \dot{m}v^2[/tex]
  • · Replies 20 ·
20K
10K
