| Thread Closed |
Converting electricity to heat |
Share Thread | Thread Tools |
| Mar18-10, 04:55 PM | #1 |
How do steam-irons/flat-irons directly convert electricity to heat?
| Mar18-10, 05:06 PM | #2 |
Mentor
| Apr5-10, 11:55 PM | #3 |
Recognitions:
Steam irons etc contain a large resistor which gets hot when electric current is passed through it.
This heat is conducted to the flat plate by metals which are good heat conductors but the electricity is insulated from the rest of the iron by a non metal which is a good electrical insulator (but a good conductor of heat.) You can calculate the heat power generated. The unit is the WATT. Power = voltage times the voltage, divided by the resistance of the resistor. For example if the voltage was 110 volts and the resistance of the resistor was 12 ohms, the heat power generated would be 110 * 110 / 12 or 1008 watts. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Converting electricity to heat
| Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity | Advanced Physics Homework | 4 | ||
| Thermopile, let extract some electricity from heat without steam | Electrical Engineering | 8 | ||
| Solar Voltaic Cells -- converting sunlight to electricity over a given area | Introductory Physics Homework | 8 | ||
| Question on converting heat to kinetic energy. | Mechanical Engineering | 0 | ||
| relating heat to fire to light to pressure to electricity | General Physics | 1 | ||
