Discover the Best Way to Cool Your Coffee in Just 5 Minutes: Milk vs. No Milk
  • Context: High School
  • Thread starter Thread starter BL4CKCR4Y0NS
    Coffee
The discussion revolves around the optimal method for cooling coffee within a five-minute timeframe, specifically debating whether to add cold milk before or after this cooling period. The conversation touches on concepts from thermodynamics, including entropy and Newton's cooling law, and explores the implications of these theories in practical scenarios.
  • Some participants suggest that adding milk first creates a greater temperature difference, which may lead to more irreversible changes and energy loss, thus advocating for waiting to add milk.
  • Others argue that Newton's cooling law provides a clearer understanding of the cooling process, emphasizing the mathematical relationship between temperature and time.
  • One participant introduces a graphical approach to demonstrate that the timing of adding milk does not affect the final temperature when certain conditions are met, specifically when the milk temperature equals room temperature.
  • Another participant acknowledges the role of entropy in the cooling process, suggesting it is a fundamental consideration despite initially underestimating its importance.
  • Participants propose different scenarios based on the relative temperatures of the milk, room, and coffee, outlining conditions under which it is preferable to add milk early or late.
The discussion contains multiple competing views regarding the best approach to cooling coffee, with no consensus reached on the optimal method. Participants express differing opinions on the relevance of entropy and the application of Newton's cooling law.
Participants reference various assumptions about the temperatures involved and the specific conditions of their setups, which may influence the outcomes of their proposed methods. The discussion remains open-ended with unresolved mathematical steps and varying interpretations of thermodynamic principles.
BL4CKCR4Y0NS
"This famous problem is always interesting. Suppose you want to make your morning coffee cool off within five minutes to make it a more suitable temperature. Do you pour the cold milk first and then wait five minutes before drinking, or d you wait five minutes before adding the milk?"
I *THINK* that you should wait five minutes then add the milk but I'm not sure...
Any ideas?
Science news on Phys.org
Any ideas?
I think this is an entropy issue ... the greater the temperature difference, the more irreversible the change upon adding the milk, and thus less energy will be wasted if you allow the coffee to cool first, and then add the milk. So I agree with you ...
You don't need entropy to understand this. Just apply Newton's cooling law:
T(t) = Tr + (T0 - Tr)exp(-k*t)
And the well-known formula for the temperature of the mixture of two fluids:
Tmix = (T1*M1 + T2*M2)/(M1 + M2)
Where Tr is the temperature of the room and T0 is the initial temperature of the coffee, and k is a constant that depends upon your particular setup. T(t) is the temperature after t amount of time. In the second formula, T1,M1,T2,M2 are the temperature and mass of the first and second liquids, respectively.
Any ideas?
i think, when u add milk first then it follows zeroth law of thermodynamis. then after some time it follows the law.but after waiting of 5 minutes there will be no distribution of heat.
*facepalm* Of course, how could I have forgotten Newton's cooling law! That certainly accounts for most or all of the difference, and would dominate any effects from my "entropic cooling efficiency" hypothesis (if it is even correct).
However, it seems clear that the *reason* for Newton's cooling law is simply the 2nd law of thermodynamics, and entropy is the driving force. So, entropy *is* the essential consideration, just not in the way I hypothesized. *wink*
this was fun.
let;
Tm = temperature of the milk,
Tr = temperature of the room,
T(t) = temperature of the coffee, w/o the milk
T'(t) = temperature of the coffee, w/ the milk
T0 = initial temp of the coffee (HOT!)
K: a constant between 0 and 1 depending on the ratio of mass of the milk and coffee. Something like Mc / (Mc + Mm)..
For a colder coffee, at the end of 5th minute;
if Tr < Tm < T0; put the milk as soon as you can.
if Tr = Tm < T0; it doesn't matter when you put the milk.
if Tm < Tr < T0; put the milk as late as you can.
I came to the conclusion graphically, using exponential cooling model and mixture of fluids. Its easier to visualise that way. But I'll try to pour it on maths:
Let's just consider the case Tm = Tr. We left the milk on the kitchen table last night, its at room temp in the morning.
normally T(t) = Tr + (T0 - Tr)*exp(-kt)
if you put the milk at t=0;
T'(t) = Tm + K*[T(t) - Tm],
so at 5th minute temperature of the coffee is;
T'(5) = Tm + K*[T(5) - Tm] *** (1)
and if you put the milk at t=5th minute;
T'(t) = T(t) - H(t-5)*(K-1)*[T(t) - Tm]
where H(t) is the Heaviside step function.
just after we pour the milk, at t=5+, the temperature is:
T'(5+) = T(5+) + H(0+)*(K-1)*[T(5+) - Tm]
T'(5+) = T(5) + (K-1)*[T(5) - Tm]
T'(5+) = T(5) + K*[T(5) - Tm] - [T(5) - Tm]
T'(5+) = Tm + K*[T(5) - Tm] *** (2)
aha! (1) = (2). it doesn't matter when you put the milk, if Tm=Tr
The other cases; Tr < Tm and Tm < Tr can be proved graphically much easier.
Well BL4CKCR4Y0NS has cold milk in mind, so yes - he should pour the milk in as late as possible.
Voila - physics applied to make real life better.
16K
  • · Replies 25 ·
  • · Replies 152 ·
12K
10K
