Will light be trapped in a room full of mirrors?
  • Context: High School
  • Thread starter Thread starter PLYeo
    Light Mirrors
The discussion revolves around the feasibility of trapping light in a room filled with mirrors, exploring theoretical and experimental aspects of this concept. Participants examine the implications of mirror quality, radiation pressure, and the nature of light reflection.
  • Some participants suggest that light could be trapped if the mirrors are sufficiently reflective and the conditions are ideal.
  • Others argue that radiation pressure would prevent light from being truly trapped, as each reflection would exert a force on the mirrors, potentially causing movement.
  • A participant mentions that perfect mirrors do not exist, leading to eventual energy loss through absorption and scattering.
  • There is a discussion about the concept of total internal reflection and its limitations, including energy losses due to surface plasmons.
  • Some propose that a highly reflective mirror combined with a long beam path could yield observable effects, although this would still be temporary.
  • One participant questions how to align imperfect mirrors perfectly, highlighting the challenges in achieving the theoretical conditions needed for trapping light.
  • Another participant reflects on the practical implications of light disappearing when a bulb is turned off in a mirrored room, expressing curiosity about the behavior of light in such scenarios.
  • A later reply mentions that while light can be trapped momentarily, it would not remain trapped for long due to the inherent limitations of mirror reflectivity and the speed of light.
Participants express a range of views, with no consensus on whether light can be effectively trapped in a room full of mirrors. While some believe it is theoretically possible under certain conditions, others emphasize the practical limitations and challenges involved.
Limitations include the dependence on the quality of mirrors, the effects of radiation pressure, and the impossibility of achieving perfect conditions for trapping light. The discussion also touches on the complexities of measuring light behavior in such setups.
PLYeo
Will light be trapped in a room full of mirrors? Can this experiment be done?
Science news on Phys.org
If the mirror is cool enough, then yes.
wouldn't radiation pressure make impossible to "trap" light? since every reflection off the mirror would need the mirror to experience twice the force of the intensity of the light wave. which, although small, would cause movement to the mirror. kind of like a solar sail.
Sure but you could easily imagine compensating for this with some external pressure. The real kicker is that there exist no perfect mirrors, so eventually the photons will not be re-emitted. Also, it is impossible to construct a geometry such that you can emit a photon and have it never impact the photon source. So you have to imagine a situation where you shine a light into a chamber and very shortly afterwards "close" the chamber before the light has a chance to escape.
I think I read a thread earlier on this forum about trapping light in a PERFECTLY ROUND ball with a PERFECT vacuum inside. And the inside surfaces of this ball are PERFECTLY reflective. Now just reading that you would know that this is impossible.
I don't remember the answer exactly but I think it was there would be a lot of energy trapped within the ball. I can't remember the end result though ...
There are still losses with TIR - energy is released as surface plasmons into the surrounding material, and of course there are absorption losses in the material.
You can do pretty well though with optical fibre at the right wavelength
TESLACOILZAP said:
30 miles say 1000 reflections with the best mirrors mankind could make the light would dim in 1/6th of second , just long enough for you to perceive it dimming
Erm no, you can't see light unless it goes into your eye.
If you put your head in the beam you would see the light, but that would also stop it.
To get the 'delay' I think you'd have to not watch the beam for a while, whilst it's decaying, and then 'stick your head in the way' (or use some fast mirror arrangement) to see what's left of the light energy. Otherwise, the very fact of observing the process would reduce the decay time significantly.
well if you were to light a bulb in a room with 100% mirrors comprising its inner surface, as soon as you turn the bulb off then I'm sure the light would disappear!
I wish I knew enough basic physics to know where that light goes, lol.
I still wonder what happens in the fridge when I shut the door. The greens stay green so perhaps it stays on. There's not room inside for me to stay in and check, though.
1. The radiation pressure wouldn't be a problem as long as you attached the two mirrors together. Then the momentum can be conserved as the apparatus goes one way the photon goes the other. The other solution of having a pressure outside wouldn't work because the impulse of the photon would still be transferred to the mirror which would expand into the pressurised gas, doing work...2. With a highly reflective mirror and a long beam path I bet you could get an observable effect though. You'd set the source moving perpendicular to the beam and have a detector facing the same way, following and slowly catching up, so it collected reflected light in a time domain which is proportional to the time the light has been reflecting, until it reaches the source and collects light after only a single reflection.3. Theoretically I can't see why not if you have an infinite amount of perfectly aligned (but imperfect) one-way mirrors, the problem becomes a 1D random walk for the photon with a bias towards the cavity since it is more likely to be reflected than transmitted. Then in a Markov chain the state for the photon to be in the cavity is recurrent, so the answer is "yes".
How do you perfectly align imperfect mirrors.
I meant imperfect = they have less than 100% reflectivity. I didn't make that clear.
There is no real answer to this question.
TESLACOILZAP said:
I think we have the answers
1 light can of course be trapped in a room full of mirrors. the laws of physics allow it to be reflected
2 it won't stay trapped for long because light moves so fast and no mirrors are prefect & absorb some light with each reflection
meaning you would need an impossibly large box , or and impossibly perfect mirror...Impossible in human terms anyway...except for a few a milliseconds in lab or science show demonstration
I suppose you are correct, although it would be very hard to measure this.
This has actually been done but it isn't easy and it isn't for long (in human terms at least):
http://www.cosmosmagazine.com/news/1101/envisaged-einstein-photon-trap-built
  • · Replies 64 ·
  • · Replies 22 ·
