Heat and mass transfer empirical equations
  • Context: Graduate
  • Thread starter Thread starter bill nye scienceguy!
    Heat Mass Mass transfer
The discussion centers on the derivation of empirical equations in heat and mass transfer, particularly in the context of multi-stage flash distillation plants. Participants agree that identifying governing equations involves combining relevant variables and fitting them to experimental data, akin to least squares fitting. Historical references include Einstein's development of General Relativity and the evolution of electrical feedback equations, highlighting the iterative nature of scientific discovery. Modern advancements in numerical analysis techniques are acknowledged as tools that can streamline this process.
  • Understanding of empirical equations in engineering contexts
  • Familiarity with heat and mass transfer principles
  • Knowledge of least squares fitting techniques
  • Basic concepts of numerical analysis methods
  • Research numerical analysis techniques for empirical equation derivation
  • Explore advanced heat and mass transfer modeling software
  • Study the application of least squares fitting in engineering
  • Investigate historical case studies of empirical equation development
Engineers, researchers, and students in the fields of heat transfer, mass transfer, and empirical modeling who seek to understand the methodologies behind deriving governing equations from experimental data.
I guess this question applies to deriving empirical equations from any data set but in my engineering studies I've wondered this when working with heat and mass transfer.
When you do an experiment and want to identify the governing equation for the process, is it simply a case of bringing together all the variables you think appropriate and then trying to make an arrangement of them fit the curve on your graph?
It crosses my mind now as I'm working out the performance ratio of a multi-stage flash distillation plant and wondering how the hell someone derived this equation with 9 different terms, 7 different variables and 2 constants!
Science news on Phys.org
generally, yes, that's a good description. I have no idea how the specific equation you describe was developed, but likely it did not happen all at once...likely someone took a stab at it and someone else improved it...and it was gradually developed. It's analogous to fitting a straight line to a bunch of data points via a least squares fit...maybe that's accurate enough maybe not...for Hubble, as an example, that seemed to do the trick developing H0, the Hubble constant.
What you describe is also pretty much what Einstein did developing GR...he started from the famous insight, his equivalence principle, and so was able to derive a number of answers from the acceleration analogy to gravity...he had a number of different formulations and apparently discarded one by one them based on his understanding of how well they would match his anticipated behavior for the phenomena...In his case he did not even know how to do the math at first, his former teacher researched and found Riemannian geometry for Einstein...and Einstein leaned on other earlier formulations as well, like those of Lorentz and fitzgerald...
Another example is developing a feedback equation for some electrical system...a trick is to correlate the transfer function of the circuit with poles and zeros...one can then plot the results and get a visual representation of behavior...but before that mathematical trick was learned, it must have taken incredible trial and error and intuition to design a circuit with desired characteristics.
Today, I'm sure there must be some numerical analysis techniques that are computerized that can do a lot of what you suggest quickly and efficiently.
  • · Replies 0 ·
  • · Replies 20 ·
13K
