A charged particle moves across a constant magnetic field
A charged particle moving across a constant magnetic field experiences a magnetic force that is always perpendicular to its instantaneous direction of motion. This force does not change the particle's speed but causes it to accelerate, resulting in circular motion if the initial velocity is perpendicular to the magnetic field. The discussion clarifies that the magnetic force cannot be in the same direction as the particle's motion, which invalidates the choice of option C in the context of the posed question. The correct understanding is that the magnetic force leads to a change in direction, not speed, confirming the particle's circular trajectory under specific conditions.
  • Understanding of magnetic forces and their effects on charged particles
  • Knowledge of circular motion principles in physics
  • Familiarity with the right-hand rule for determining force direction
  • Basic concepts of acceleration and velocity in physics
  • Study the Lorentz force law and its applications in electromagnetism
  • Learn about the dynamics of charged particles in magnetic fields
  • Explore the concept of cyclotron motion and its implications
  • Investigate the effects of varying magnetic field orientations on particle trajectories
Physics students, educators, and anyone interested in understanding the behavior of charged particles in magnetic fields.
Dx
Hi,
a charged particle moves across a constant magnetic field. the magnetic force on this particle?
What would you agree on?
a) changes the particles speed b) causes the particle to accelerate c) is in the direction of the particles motion or both a & b.
I chose C but my test was marked as incorrect why??
Now, the force exerted on a charged particle by a magnetic field is always perpendicular to its instantaneous direction of motion. Does this mean that the field causes the particle to execute a circular orbit? Suppose that a positive particle of charge and mass moves in a plane perpendicular to a uniform magnetic field . the field points into the plane of the paper. Suppose that the particle moves, in an anti-clockwise manner, with constant speed (remember that the magnetic field cannot do work on the particle, so it cannot affect its speed) in an circular orbit of radius . The magnetic force acting on the particle is of magnitude and, according to the right-hand rule, this force is always directed towards the centre of the orbit.
Not necessarily, but if the initial velocity is perpendicular to the field then it will. If not, then you would get spiral motion. But in your problem here, the initial motion is perpendicular to the field, so the trajectory will indeed be circular.
You haven't stated the question. I will assume the answers correspond to the question, "The magnetic force does what to the particle?" That makes the most sense.
Dx, think!. At the beginning of this very post, you said that the force is perpendicular to the motion[/color]. How on Earth could it also be in the same direction as the motion[/color]?
I agree with your choice of C. The magnetic force on a charged particle moving across a constant magnetic field is both in the direction of the particle's motion and causes it to accelerate. This is because the force is always perpendicular to the particle's motion, so it does not change its speed, but it does change its direction, resulting in acceleration.
As for your test being marked incorrect, it's possible that there was a mistake in the grading or that there was a specific answer that was expected. It's always best to check with your instructor for clarification if you have any doubts about a graded test or assignment.
Regarding the circular orbit, yes, in this scenario, the particle would execute a circular orbit due to the constant magnetic force acting on it. This force is always directed towards the center of the orbit, resulting in a circular path. However, this is only true if the particle's velocity is perpendicular to the magnetic field. If the velocity has a component parallel to the field, the particle will not follow a circular path.
  • · Replies 31 ·
